Old 08-27-2013, 04:56 PM   #1
sidswiftsteel
Drives: Galaxy Blue Silica BRZ
Remove gas cover appliqué
Has anyone successfully removed the gas cover appliqué without damaging the cover door? What's the best method. I briefly tried to use some floss but that sucker is on there good.
Will heating it up a little help or any other suggestions? I'm really unhappy with the look of that appliqué so it needs to go!
Thanks
sidswiftsteel is offline   Reply With Quote
Old 08-27-2013, 05:12 PM   #2
Gary in NJ
Gary in NJ's Avatar
Drives: WR Blue BRZ, 240Z
What exactly are you referring too? My fuel cover door is painted like the rest of the car.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
Gary in NJ is offline   Reply With Quote
Old 08-27-2013, 05:44 PM   #3
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
Its a dealer-option decal.
supramkivtt2jz is offline   Reply With Quote
Old 08-27-2013, 05:50 PM   #4
Colombo
Drives: '13 BRZ
I'm betting you can find someone in your area with the same color car that would want to just trade doors. You can't damage it that way. Just an idea.
Colombo is offline   Reply With Quote
Old 08-27-2013, 08:22 PM   #5
Gary in NJ
Gary in NJ's Avatar
Yeah, I don't blame you for wanting to remove that.
I would think that "Goo-be-Gone" would do the trick on that. It should only loose the adhesive and not effect the paint. It's no where near as hot as Goof-Off.
Old 08-27-2013, 09:07 PM   #6
Shagaliscious
Drives: Firestorm FR-S (MT)
Yes, heating it up will help. Heat gun would be best, but if you don't have one, a hair dryer would work too, just take longer. Use goo gone along with the heat gun, and you should have no problem removing it with floss. That's how I removed the "ivtec" decals on the side of my Si.
Old 08-27-2013, 10:50 PM   #7
TheseColorsDontRun
Keep calm and drive on
TheseColorsDontRun's Avatar
Drives: 2013 WRB BRZ Limited 6M
Yep, heat and any of the goo removal products will take care of the sticky stuff left behind.
TheseColorsDontRun is offline   Reply With Quote
Old 08-27-2013, 11:13 PM   #8
Vten
Drives: Too heavy
park your car under the sun for a couple of hours , and start to peel out the egde and just yanked it , if there's a residue left, use goo gone .
the faster you peel that stupid sticker off the fuel door the better , because itll leave a mark if you take it off later
Vten is offline   Reply With Quote
Old 08-30-2013, 12:20 PM   #9
sidswiftsteel
Thanks for the tips. I'm going to try to heat it up a bit then remove.
Old 09-13-2013, 04:31 PM   #10
sidswiftsteel
Finally got rid of it. Floss wasn't able to get behind it so I used a fingernail to get it started. Then it was just a matter of just slowly peeling it back. Cleaned and waxed.... Now onto the chrome fender trim! =)
The Following User Says Thank You to sidswiftsteel For This Useful Post:
ChilOut (07-02-2014)
Old 11-14-2013, 11:10 PM   #11
dontpanic
Drives: shiny side up.
yep, heat gun; then goof-off for left over glue. use a microfiber not a paper towel to clean up glue.
dontpanic is offline   Reply With Quote
Old 12-15-2013, 05:06 PM   #12
AgentH
Drives: 02 WRX Wagon
How did the paint look after you removed the Applique?
AgentH is offline   Reply With Quote
Old 12-15-2013, 06:05 PM   #13
cjsporl1996
Drives: WRB BRZ, Monte Carlo SS
Nooooooo I would of traded fuel doors with you we Even have the same color door.
cjsporl1996 is offline   Reply With Quote
Rear Bumper Applique Issues hur1ey02 Scion FR-S / Toyota 86 GT86 General Forum 22 06-04-2013 08:59 AM
Best way to remove the Scion Rear Bumper Applique? Tim_Asphalt_FRS Cosmetic Modification (Interior/Exterior/Lighting) 28 12-25-2012 01:30 AM
Remove mirror cover and fender side vents? CharlieChaos DIY (Do-It-Yourself) Guides 5 11-10-2012 03:46 PM
FS: Rear Bumper Applique [SCION] Bonburner Exterior Parts (Aero, Lighting, Etc.) 11 10-27-2012 08:06 PM
will polishing your car to remove swirls remove opti-coat? bacon_cheese_beer Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 11 10-25-2012 10:41 PM
