Old 07-29-2012, 12:04 AM   #1
CharlieChaos
Drives: FRS
Remove mirror cover and fender side vents?
Anyone know how to remove the exterior Mirror covers and the side vent with the 86 logo?
CharlieChaos is offline   Reply With Quote
Old 08-12-2012, 09:12 PM   #2
thermobox
Drives: 16 Impreza 5dr CWP
I can't speak for the Scion.
But for the Subaru:
Mirror covers can be removed by hand. I usually use my fingernail or a trim removal tool to make a gap. Then they pull off.
The fender garnish requires:
Heat gun to loosen the sticky tape
Wire to slide through the sticky tape
Moulding remover to remove the six clips
Could be different on the Scion though? idk.
thermobox is offline   Reply With Quote
Old 08-12-2012, 09:26 PM   #3
eriktherod
Drives: 2013 Scion FR-S Firestorm Red MT
The faux vent or the 86 emblem? The 86 piston ornaments are held on with adhesive and two alignment 'pin', similar to the front badge.
eriktherod is offline   Reply With Quote
Old 08-12-2012, 09:50 PM   #4
Drunknhero
Drives: 13 Firestorm
wish someone would do a DIY for this. Thinking of taking off the 86 Piston to repaint it.
Drunknhero is offline   Reply With Quote
Old 08-14-2012, 10:42 AM   #5
sbxjap
sbxjap's Avatar
Drives: '95 Honda Civic HB/'13 Subaru BRZ
someone already said how it's held one. It's 3M double sided tape with a plastic guide pin on either side... the pins aren't lined up though.
sbxjap is offline   Reply With Quote
Old 11-10-2012, 03:46 PM   #6
LOZZI
LOZZI's Avatar
Drives: 2013 FR-S (Raven)
The seems are tight for removing the side mirror caps. A credit card, a microfiber towel, and some blue mask tape helped me.
LOZZI is offline   Reply With Quote
question about brz/fr-s front fender vents nmullin11 Cosmetic Modification (Interior/Exterior/Lighting) 23 03-20-2013 05:01 AM
Functional front fender vents JohnATL Cosmetic Modification (Interior/Exterior/Lighting) 10 01-25-2013 11:58 AM
Blue Engine Cover & Frameless Rearview Mirror where to buy? JDM-dono AUSTRALIA 19 07-26-2012 08:41 AM
Does anyone know Part Number for side Vents?? stevo_12v Cosmetic Modification (Interior/Exterior/Lighting) 2 05-16-2012 10:30 AM
Fender Vents real or fake KaliKev Scion FR-S / Toyota 86 GT86 General Forum 48 12-03-2011 01:24 PM
