Old 08-20-2013, 10:18 PM   #1
Frs32907
Drives: Asphalt grey, manual Fr-S
Driving slow hearing sound on driver side like metal hitting eachother
Just started today. When i drive really slow i hear something that sounds like metal hitting when accerating and faster than 10mph ita not there
Frs32907 is offline   Reply With Quote
Old 08-20-2013, 10:23 PM   #2
Accurate Race Shop
Accurate Race Shop's Avatar
Drives: Scion FR-S
I have a similar issue. It sounds like something in the suspension might me a sway bar end link. I am going to check it out this weekend when I install my brakes.
Old 08-20-2013, 10:24 PM   #3
Frs32907
Does it go away at higher speeds?
Old 08-20-2013, 10:41 PM   #4
Accurate Race Shop
Drives: Scion FR-S
yeah normally when shifting into 1st and second I hear it. sounds like a small knock like someone is tapping something with a hammer
Old 08-21-2013, 10:57 AM   #5
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
heatshield?
Old 08-21-2013, 03:13 PM   #6
FRiSson
Drives: FR-S MT
I find it hard to keep track of all the sounds that come and go over time. I am going to train myself to ignore the benign-sounding ones. Yes, its doable.
FRiSson is offline   Reply With Quote
Old 08-25-2013, 06:44 AM   #7
Accurate Race Shop
Drives: Scion FR-S
Well I put the breaks on and inspected everything and I couldn't figure out where the noise is coming from so I'm going to take it to the dealer tomorrow.
Sent from my Q10
Old 08-25-2013, 06:52 AM   #8
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
have you changed the wheels?
i had this, I eventually found it. turned out to be something inside the tyre, the valve stem nut had come undone.
86•BRZ is offline   Reply With Quote
Old 08-25-2013, 08:43 AM   #9
Accurate Race Shop
Drives: Scion FR-S
Yeah I replaced the tires and wheels. It sounds more from the center of the car. Because I still have my warranty I think I'll let the dealer sort it out to save me some time. Normally I would work on it until I figured it out but I have just been to busy to set aside an afternoon to mess with it.
Old 08-25-2013, 03:17 PM   #10
xjohnx
Grip>Slip
xjohnx's Avatar
Check your inner CV's?
Old 08-25-2013, 03:18 PM   #11
chutrain
chutrain's Avatar
Drives: WRB BRZ
Check the endlinks. I had the clanking issue and could not find anything. Yanked at the the endlinks and heard nothing. Turns out one of the nuts were slightly loose.
In the garage:
1988 BMW E30 M3
2003 Ducati ST4s ABS
2006 Subaru Legacy GT Spec B #444/500 (For Sale)
2013 Subaru BRZ WRB Limited - Acquired 9/15/12
chutrain is offline   Reply With Quote
Old 09-03-2013, 10:53 PM   #12
Accurate Race Shop
Drives: Scion FR-S
Mine is going to make it to the dealership tomorrow I received the warning "we haven't worked on many of these but we will give it our best shot" so I can only hope for the best. This is just a toyota dealer they don't sell scions but the next closest dealer is over an hour away so here's to hoping for the best.
Sent from my Q10
Old 09-03-2013, 11:01 PM   #13
husker741
Sound like the video that's in my first post in this thread? http://www.ft86club.com/forums/showthread.php?t=43936
If so, this is the problem. http://www.ft86club.com/forums/showthread.php?t=41762
And this. http://www.ft86club.com/forums/showthread.php?t=40463
husker741 is offline   Reply With Quote
Old 09-04-2013, 03:42 AM   #14
Silver86
Silver86's Avatar
Drives: Argento FR-S
I have a bit of a clanking sound as well. They put the washer (that should have been installed at the factory) on the heat shield bolt so it wouldn't come loose again and since then its been fine.
It doesn't sound extremely abnormal and my friend with a brand new BRZ has the same sound sometimes. Its only in 1st and 2nd.
Silver86 is offline   Reply With Quote
Clanking metal sound from rear!!!! 808Raven Issues | Warranty | Recalls / TSB 7 09-21-2017 10:09 AM
Light buzzing sound from driver-side dash BRZprime Issues | Warranty | Recalls / TSB 51 08-21-2015 09:34 PM
More sounds; metal whirring sound braking to stop in neutral l0aded Issues | Warranty | Recalls / TSB 2 07-13-2013 02:05 AM
Hawks HP Plus metal clip on the wrong side cityhugo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 03-01-2013 01:28 PM
Mr. Sociable's BRZ Daily Driver (slow) Build Mr. Sociable Member's Car Journals 23 11-01-2012 09:46 AM
