Old 02-22-2013, 09:09 PM   #1
MosesFRS
MosesFRS's Avatar
Drives: Whiteout
2013 FRS fuel pump sound
Two weeks after buying I had the car parked in the garage for about two hours after my wife got home and I could hear what sounded like a gear turning coming from the gas tank. Can only assume it was the fuel pump. Turned the key over to let the pump cycle and the noise was gone. Just weird it happened after the car had been sitting.
MosesFRS is offline   Reply With Quote
Old 02-22-2013, 09:23 PM   #2
Tiremonkey0824
Drives: 2013 Argento 6mt
I hate to be "that guy", but if you searched you would have found numerous threads explaining this. It's also in your manual, take a look and it will explain everything to you.
Tiremonkey0824 is offline   Reply With Quote
Old 02-22-2013, 09:37 PM   #3
Porsche
Drives: 2013 BRZ Ltd. MT
See pg. 14 in the Subaru Owner's Manual:
"Approximately five hours after the engine is turned off, you may hear sound coming from under the vehicle for several minutes. This is the sound of a fuel evaporation leakage check, and it does not indicate a malfunction."
It's just modern technology as the car goes about its business ... hours after you've parked it.
Spooky, isn't it?
Porsche is offline   Reply With Quote
Old 02-22-2013, 09:44 PM   #4
MosesFRS
MosesFRS's Avatar
Drives: Whiteout
Spooky, isn't it?
Yes it is, I did a search and I guess I didn't type the correct thing so nothing similar.
Old 02-22-2013, 09:44 PM   #5
MosesFRS
MosesFRS's Avatar
Drives: Whiteout
The time you took, should have just said nothing and moved on.
Old 02-22-2013, 09:59 PM   #6
Tiremonkey0824
Yeah same with your post and the one I'm typing now...
Old 02-22-2013, 10:11 PM   #7
Lonewolf
Lonewolf's Avatar
Drives: Moped
Noobs sure are snarky these days...
Old 02-22-2013, 10:19 PM   #8
blackraven1425
Drives: raven at
No reason to give them shit, everyone has been there. Remember- everyone starts as a noob.
blackraven1425 is offline   Reply With Quote
Old 02-22-2013, 10:23 PM   #9
Lonewolf
Lonewolf's Avatar
Drives: Moped
Old 02-23-2013, 09:01 AM   #10
BRZnut
Drives: BRZ DGM Limited
Mine does the same thing some times after sitting in the garage for a few hours and it is normal. Makes a buzzing mechanical sound from the back.
I've been able to translate what the car is saying when this happens with a special program from Japan........."Drive me again/Drive me again" ........
ready to take your f for the fuel pump recall?? xpicer NY / NJ / CT / PA 21 09-30-2013 11:12 AM
Fuel pump issue. sevi21 Issues | Warranty | Recalls / TSB 13 02-01-2013 09:57 AM
New tail lights and fuel pump inc MindtheGap Mid-Atlantic 14 12-19-2012 07:42 PM
Car fuel pump on... Genomaxter Engine, Exhaust, Transmission 5 11-29-2012 10:06 AM
Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump Dustin@Dynosty Engine, Exhaust, Bolt-Ons 3 08-21-2012 04:53 PM
