Old 08-01-2013, 10:54 AM   #1
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
Front control arm cam bolt
I just ran into this when looking up some part numbers:
http://www.villagescionparts.com/pro...U00300399.html
Apparently, there are cam bolts available for our cars from Toyota.
PN SU00300399 - Find NO 48194E and 48198E on this diagram:
It also seems to be used on the rear upper control arms
supramkivtt2jz is offline   Reply With Quote
Tow hook Rear/Front bolt size?? Scion FR-S pnaysh0rty Cosmetic Modification (Interior/Exterior/Lighting) 25 04-28-2016 08:26 PM
Perrin Front Control Arm Braces grodenglaive DIY (Do-It-Yourself) Guides 7 10-29-2014 04:07 PM
Alignment needed after front camber bolt install? ayau Suspension | Chassis | Brakes -- Sponsored by 949 Racing 60 08-31-2013 12:13 AM
Front Control Arm Bushings. feldy Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 03-02-2013 05:35 AM
Front Caliper Bolt Pattern kmbkk Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 11-08-2012 11:21 AM
