Old 04-17-2013, 03:21 PM   #1
grodenglaive
Drives: asphalt FR-S
Perrin Front Control Arm Braces
Installation of these is dead easy, just two bolts per brace and the only thing you need to remove is the front wheels. I'm posting up more to point out that the instructions supplied with the braces state the wrong torque values.
Perrin says to tighten them to 110 ft.lbs, but the FR-S service manual says 110 NM - which is only 81 ft.lbs. That's enough of a difference that someone might snap the head off a bolt and that would really suck. I also used (and recommend) red loctite on the threads. You could see that there was loctite on there from the factory, so it should be reapplied. You definitely don't want these getting loose.
Anyway - the braces are very well made, beautifully finished, and fit perfectly. They appear to be much more solid than OEM. I don't know if they affected the handling as I also installed camber bolts at the same time.
grodenglaive is offline   Reply With Quote
Old 04-17-2013, 09:04 PM   #2
BAS
Drives: Snow White
Agreed. Bad information provided on their part. I have the Cusco Front Control Arms. I did not take my wheels off during installation. Maybe I should have...whoops! I was able to use low-profile jack for support while car was well secured on 4 floor jack stands.
hmm...
TRD Exhaust/Cold Air Intake/High Pressure Radiator Cap (1.3 bar/18.5 psi)/Door Stabilizer, Cusco Front/Rear Type OS Strut Tower Brace/Power Engine Member Brace/Rear Member Brace, 215/45ZR17 PSS, Perrin Master Cylinder Brace/Shorty Antenna/Front Tow Hook License Plate Mount, TWM M1 Abrams White Pearl Shift Knob, SilverStar Ultra H11/9005, OEM Auto Dimming/Home Link Rearview Mirror, Full LED's with Switchbacks and JDM Clear Sidemarkers
BAS is offline   Reply With Quote
Old 04-17-2013, 11:02 PM   #3
Retro86
Retro86's Avatar
Drives: Awesome
any pics?
Retro86 is offline   Reply With Quote
Old 04-17-2013, 11:14 PM   #4
whataboutbob
AutoX-10/10ths every run
Here are mine in the bag still. Got them through @JoeBoxer. I'll be mounting them this weekend.
Build thread:Here
Old 04-19-2013, 04:03 PM   #5
f0rge
head of infinite swagger
Drives: 2013 FR-S 6MT
What's the verdict on these or the Cusco ones? Noticeable difference?
2019 Golf R 6MT - current daily...I need another coupe
2008 Civic Si - winter beater
2000 Silverstone M5 6MT - SOLD
2013 Ultramarine FR-S 6MT - Car Journal - SOLD
2004 AlpineWhite M3 6MT - SOLD
f0rge is offline   Reply With Quote
Old 04-19-2013, 04:12 PM   #6
PERRIN_Mladen
PERRIN_Mladen's Avatar
Drives: '11 535i
Thank you for catching that for us! We have gone in and changed the instructions to say 81 ft-lbs! However, if you, or anyone, has already tightened the bolts down to 110 ft-lbs that is perfectly ok as well.
PERRIN_Mladen is offline   Reply With Quote
Old 04-19-2013, 06:11 PM   #7
phanguy
phanguy's Avatar
Drives: Scion FR-S Ultramarine
I did it to 110ft/lbs... seemed to be okay. haha.
phanguy is offline   Reply With Quote
Old 10-29-2014, 04:07 PM   #8
sweetfrs
sweetfrs's Avatar
Drives: 2013 FRS
i ordered mine the other day because my stock one got bent, long story. is there any added performance benefits from this product ?
sweetfrs is offline   Reply With Quote
Perrin or Invidia Catted Front Pipe? husker741 Engine, Exhaust, Transmission 30 08-24-2017 12:26 PM
ROBISPEC Front ADJUSTABLE tubular lower control arms robispec Suspension | Chassis | Brakes -- Sponsored by 949 Racing 75 04-05-2015 09:36 AM
EVO3 w/ Perrin Front Pipe? BigJyoungblood Engine, Exhaust, Transmission 13 04-09-2013 01:37 PM
Front Control Arm Bushings. feldy Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 03-02-2013 05:35 AM
Cusco Front & Rear Strut Braces [BNIB] GC GTS Aero Kit Australia Classifieds 8 12-04-2012 07:58 AM
