Old 07-19-2013, 08:57 AM   #1
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Question Lowered car about 1.25" Adjustable Endlinks needed?
So I was following a thread and believe I have found the culprit of a little annoying sound on my front suspension.
The stock front endlinks have preload on them right now, making the sway bar be out of place.
Now, my question is, with my car lowered about 1.25", do I need adjustable endlinks in the front and the back, or only the front?
I am about to buy the front ones and will install them at the same time as rear LCA's, but don't want to buy them only to find out I need them on the back too.
Old 07-19-2013, 10:43 AM   #2
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Inquiring minds want to know, I have similar concerns.
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 07-19-2013, 10:55 AM   #3
Sportsguy83
Drives: Limited BRZ
@CSG Mike @Racecomp Engineering @GC_Adam @racerx1715
Old 07-19-2013, 12:05 PM   #4
Sportsguy83
Drives: Limited BRZ
I went ahead and ordered Whiteline Adjustable front Endlinks. Asked couple of forum members who are lower than me and none required them for the back. Front seems to be required.
Old 07-19-2013, 12:27 PM   #5
tonystewart
Thank you
The Following User Says Thank You to tonystewart For This Useful Post:
Sportsguy83 (07-19-2013)
Old 07-19-2013, 02:29 PM   #6
We are running stock in front and Whiteline in the rear. It would be helpful to run adjustables up front but we don't have any issues.
- Andy
The Following User Says Thank You to Racecomp Engineering For This Useful Post:
Old 07-19-2013, 05:00 PM   #7
YDNA
YDNA's Avatar
Drives: Raven FR-S
i cut and welded mine for the fronts because i didnt want to shell out the money nor did i want to wait two weeks for some endlinks to come in. it's been holding up fine with spirited driving. this was a last minute 2am morning thing that we did too
YDNA is offline   Reply With Quote
The Following User Says Thank You to YDNA For This Useful Post:
charged86 (07-20-2013)
Old 07-19-2013, 05:04 PM   #8
djdnz
1337
Drives: 2013 BRZ WRB S/C
Can someone elaborate on the issue? Trying to figure out what the problem is... I've seen the picture in the other thread but I dont have a clear understanding of what is happening.
djdnz is offline   Reply With Quote
Old 07-19-2013, 05:25 PM   #9
YDNA
YDNA's Avatar
Drives: Raven FR-S
when you lower your car, most people have the issue of the endlinks hitting/rubbing onto the control arm when you turn your steering wheel. its very annoying.
Old 07-19-2013, 05:34 PM   #10
chadstyle
chadstyle's Avatar
Drives: 2013 Subaru BR-Z Limited
That's interesting David. I have 1.4" drop all the way around using OEM end links and Eibach sways front and rear and I have no noises at all. I have seen a thread or two talking about this but not on a 1" drop if I remember.
chadstyle is offline   Reply With Quote
The Following User Says Thank You to chadstyle For This Useful Post:
Old 07-19-2013, 05:49 PM   #11
onefasazn
Drives: Chevrolegs
I posted about this in another thread, but Whiteline has a bunch of universal sizes:
http://www.whiteline.com.au/do_segue...NT&vehicle=ALL
onefasazn is offline   Reply With Quote
Old 07-19-2013, 06:23 PM   #12
cnk
Drives: '13 DGM BRZ Limited
I'm dropped 1" and on the stock endlinks without any issues. Seems to be an isolated few that end up with this issue.
cnk is offline   Reply With Quote
Old 07-19-2013, 11:22 PM   #13
Sportsguy83
Drives: Limited BRZ
I guess it depends on what Coilovers you get. I know to get my endlinks in place, I needed to FORCE them, because they were way off. I also saw the chasis with some marks from the endlinks rubbing.
Peolpe who only changed colis and not get coilovers, should not worry as the strut is the same. Coilovers are the ones that might have the problem.
It might also be a case of me needing to loosen the sway bar and readjust.
Old 07-19-2013, 11:37 PM   #14
cnk
Possibly. I'm on KW V3's. I didn't reinstall the sway bar until I was done installing the coilovers on both sides. I didn't have to force them in either.
The Following User Says Thank You to cnk For This Useful Post:
Adjustable Front Anti Roll Bar Endlinks for BRZ and FR-S HP Autowerks Brakes, Suspension, Chassis 4 04-24-2013 03:43 PM
Adjustable Front Anti Roll Bar Endlinks for BRZ and FR-S HP Autowerks Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 11-07-2012 11:42 PM
Front Sway Bar endlinks D1cker Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 10-30-2012 05:14 PM
Front Endlinks goke186 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 08-31-2012 02:16 AM
