Old 10-11-2012, 07:16 PM   #1
HP Autowerks
Drives: BMW 1M, Subaru BRZ
Adjustable Front Anti Roll Bar Endlinks for BRZ and FR-S
When you lower the vehicle, the swaybar is moved from the ideal factory geometry to an offset that decreases the ability of the swaybar to perform. The swaybar frame mount and the end of the bar should be on the same horizontal plane. The factory endlinks are a solid piece. When the car is lowered, the OEM links cannot compensate for the longer length needed to keep the swaybar in its ideal location. Get immediate response from your sway bar and precise control over your suspension. What this means to you is tighter, more responsive handling.
HP Autowerks is happy to introduce adjustable endlinks for your Subaru BRZ and Scion FR-S. With adjustable endlinks you can return the bar to its ideal leverage point while lowered. They also afford the peace of mind that the links or shock link mount will not fail as is common in factory units, as they will now be adjusted properly. The links are adjustable in length up to an additional 1.25" over stock. HP Autowerks end links are adjustable while on the vehicle.
HP Autowerks is offline   Reply With Quote
Old 10-11-2012, 09:23 PM   #2
simpleisbest
Senior Citizen
Drives: Scion FR-S
What's the shaft made of and are the size of the included bolts/shaft wrench flat metric?
Thanks!
simpleisbest is offline   Reply With Quote
Old 10-11-2012, 09:39 PM   #3
fatoni
theres a classified segment for this type of thing
Old 10-11-2012, 09:46 PM   #4
mike2100
mike2100's Avatar
Drives: 23 BRZ
He didn't post a price, so it's ok
OP, how much can one lower these cars before needing to compensate the end link length? The suspension geometry was apparently designed to be perfect when sitting 20mm lower than stock; I wonder if that includes the length of the end links.
mike2100 is offline   Reply With Quote
Old 10-11-2012, 10:05 PM   #5
HP Autowerks
This is a product release so the community knows what is new out there for the BRZ and FR-S.
Any suspension movement in either direction will move the anti roll bar geometry outside of the most ideal position. Adjustable endlinks will get you back to where the geometry is perfect and to take full advantage of the anti roll bar.
Old 10-11-2012, 11:17 PM   #6
chutrain
chutrain's Avatar
Drives: WRB BRZ
This looks pretty good. Any better pictures of the ends?
In the garage:
1988 BMW E30 M3
2003 Ducati ST4s ABS
2006 Subaru Legacy GT Spec B #444/500 (For Sale)
2013 Subaru BRZ WRB Limited - Acquired 9/15/12
chutrain is offline   Reply With Quote
Old 10-12-2012, 01:19 PM   #7
HP Autowerks
Thanks!
1018 mild steel
Old 10-12-2012, 01:30 PM   #8
HP Autowerks
This one should be nice and clear!
Old 10-13-2012, 04:23 AM   #9
Danzzt231
Drives: GT86
THK balljoint?
Danzzt231 is offline   Reply With Quote
Old 10-15-2012, 07:03 PM   #10
HP Autowerks
Originally Posted by Danzzt231 View Post
THK balljoint?
Yes, you are correct.
Old 10-15-2012, 09:06 PM   #11
celica73
Drives: '13 BRZ / '11 Outback / '06 Tundra
Do they have left and right threads on them, or does one end have to be removed in order to adjust the length?
celica73 is offline   Reply With Quote
Old 10-16-2012, 02:43 AM   #12
HP Autowerks
LH and RH threads. The endlinks are adjustable mounted, no need to remove them.
Old 10-17-2012, 01:45 AM   #13
Danzzt231
Drives: GT86
Quality stuff the THK balljoint.
Old 11-07-2012, 09:05 PM   #14
HP Autowerks
Bump!
Eibach Anti-Roll Kit - Press Release FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 19 07-24-2017 04:55 AM
**NEW EIBACH ANTI-ROLL KIT! SPECIAL PRICING!** genometuning Brakes, Suspension, Chassis 1 10-01-2012 01:07 PM
Front Endlinks goke186 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 08-31-2012 01:16 AM
Roll stiffness: Springs vs anti-roll bars? Captain Snooze Suspension | Chassis | Brakes -- Sponsored by 949 Racing 31 07-24-2012 05:44 PM
is it necessary to change anti-roll bar? yuli8466 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 06-25-2012 10:58 AM
