Old 07-18-2013, 01:42 PM   #1
BRZ NA
Drives: WR blue
Oil Temp Gauge installation
i m thinking to get the setrab oil cooler with mocal sandwich plate,but i want to see the difference before and after i install the cooler,so i want to install the oil temp gauge first,but i can't find any instruction on how to install an oil temp gauge (mechanical/electrical) in to the BRZ.like where to hook up wires and sensors.so can you guys help out here if you had installed one.thx
BRZ NA is offline   Reply With Quote
Old 07-18-2013, 02:46 PM   #2
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
we already have one. its on the front of the engine under the oil filter
http://www.****************/forum/at...e-imag0012.jpg
soooooooooooooooooooo apparently "modified brz . com" is not allowed on ft86club
supramkivtt2jz is offline   Reply With Quote
Old 07-18-2013, 03:44 PM   #3
ICantAffordAnLFA
ICantAffordAnLFA's Avatar
Drives: Brz, Legacy
Easy
Trackday ride with built motor
Mods: Going, Stopping, Handling
Parts: CP, Pauter, Sprintex, Ecutek, Milltek, STI, Rays, Defi, Essex AP Racing, Bilstein, Whiteline, Perrin, RacerX
ICantAffordAnLFA is offline   Reply With Quote
Old 07-18-2013, 04:13 PM   #4
GeorgeJFrick
GeorgeJFrick's Avatar
Drives: 2013 Subaru BRZ Limited LR
I use a blue tooth obd2 adapter + torque pro on Android; since as mentioned we already have a sensor.
GeorgeJFrick is offline   Reply With Quote
Old 07-19-2013, 04:21 AM   #5
1stGenBRZ86
1stGenBRZ86's Avatar
The oem sensor outputs aren't very accurate. They're usually just used to let the ecu know when something is out of range (ie. the engine is cold, or its overheating). Especially since the OP is going with an oil cooler, he's gonna want a good aftermarket gauge and sensor (defi, autometer, etc.).
I don't have the specifics for installing it on this particular vehicle, but most aftermarket sensors are 1/8" npt and most oil filter sandwhich plates have auxilary 1/8" npt ports.
I'd recommend an electric gauge, unless you don't mind having an oil line running into the cabin, with potential for leaking all over your interior.
Just follow the instructions that come with the gauge you choose.
1stGenBRZ86 is offline   Reply With Quote
Old 07-19-2013, 10:15 AM   #6
GeorgeJFrick
Citation Needed.
That said, you are probably correct. In my case, I just want to know the oil is up to temperature (Car actually warmed up). In this case, he may be looking for something more accurate...
Old 07-19-2013, 12:45 PM   #7
BRZ NA
Drives: WR blue
Thx, That's what I meant.I wanna hook up an aftermarket oil temp gauge so I can read with numbers.and also wanna c How to hook them up.
Old 07-19-2013, 12:54 PM   #8
BRZ NA
Drives: WR blue
Sorry,there is an app for android that can read oil temp in the car?
Old 07-19-2013, 01:17 PM   #9
Admiral Ballsy
Shorter of breath
Admiral Ballsy's Avatar
Drives: a soft bargain
Citation Needed.
I agree. Why would anyone manufacture an oil temperature sensor that's not accurate? Let alone spec one?
I suspect the sensor is just fine; if there are any issues, they'd be with the data that comes through the OBD stream. Some cars don't even directly measure the oil temp, they 'calculate' it based upon other inputs (lots of GM cars do this).
Admiral Ballsy is offline   Reply With Quote
Old 07-19-2013, 02:19 PM   #10
GeorgeJFrick
Yes, it's called Torque. There is a pro version that takes custom codes, which for our car includes oil temp (confirmed by manufacturer too).
There is a whole thread about it, with custom codes and showing how people have tablets mounted to dash:
http://www.ft86club.com/forums/showthread.php?t=23530
I use:
[ame="http://www.amazon.com/Excelvan-Bluetooth-Interface-Scanner-Adapter/dp/B007P14NPU/ref=sr_1_5?ie=UTF8&qid=1374257972&sr=8-5&keywords=obd+ii+bluetooth"]Excelvan ELM327 v1.5 Bluetooth Mini Small Interface OBD2 Scanner Adapter Torque Android : Amazon.com : Automotive[/ame]
Old 07-19-2013, 03:31 PM   #11
37
degrees
37's Avatar
Drives: 6MT BRZ
If you aren't building a track-only car and don't need multiple gauges displaying simultaneously, P3 makes a multi gauge that fits in your AC vent. It runs off the OBD port and looks dead simple to install.
I don't own one myself but got curious about it after seeing it in @ImperiousRex's build here: http://www.ft86club.com/forums/showthread.php?t=28008. If it's accurate and can auto toggle the display based on peak warning thresholds then it could be a solid solution for street cars seeing track use.
The dumb thing is they don't have a user manual available for download. It would be good to see the exact capabilities and limitations.
More info: http://www.p3cars.com/subaru-brz-sci...tal-interface/
37 is offline   Reply With Quote
Old 07-19-2013, 04:28 PM   #12
BRZ NA
Drives: WR blue
I use:
So How do u like it so far?accurate?
Old 07-19-2013, 05:47 PM   #13
GeorgeJFrick
Without a tablet mounted properly or anything, it isn't that useful as an active gauge. I usually seat it in the phone holder with the oil temp at the top where I can see it; and I keep an eye on it when I'm first driving waiting for the oil temp to come up.
If I drive spirited; I'll check it to see if oil temp is getting high (hasn't yet so all good).
I really like it for being a < $20.00 solution to knowing oil temp. You really have to spend more on at least a dash mount for your phone to make it useful. I find it very accurate so far, and I like being able to review my trips. You can bring up a log of your trips and see them laid out on a map with your speeds at each point. It logs other stuff too, or you can turn all logging off.
It has a 0-60 timer, etc too. Also has the code scanner and a knock detector plugin. I need to spend more time with it; it has a lot of options I haven't explored.
Old 07-19-2013, 08:24 PM   #14
BRZ NA
Drives: WR blue
cool,thx .for $20 i'll try it out.because all i need is an oil temp gauge to moniter and a timer for track use.does this app has a timer option if you know?
water temp driver01 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 30 04-11-2013 02:57 AM
A/C Oil/Water temp gauge Exhaust Scion FR-S / Toyota 86 GT86 General Forum 16 02-07-2013 01:19 PM
exterior temp. gauge off? Rayme CANADA 8 01-23-2013 09:06 PM
Simple Oil Temp. Gauge Sportsguy83 Cosmetic Modification (Interior/Exterior/Lighting) 4 01-19-2013 08:25 PM
Temperature Gauge a dummy gauge? bambbrose BRZ First-Gen (2012+) — General Topics 40 08-19-2012 04:29 PM
