Old 07-11-2013, 07:02 PM   #1
FastLane1000
FastLane1000's Avatar
Drives: White FR-S, 6M
How to pick anti-sway bars
Its time for larger anti-sway bars after adding stickier tires (Michelin Pilot SS) so how do I pick which ones and which diameter? I've not tracked the car yet but I do enjoy going to the Dragon/US129 which is close by for me (318 turns in 11 miles). The car is lowered on H&R sport springs (.85" drop) and I have the Koni sport inserts and camber bolts. I want very neutral handling which I have now but with body roll. I like the Whiteline kits cause they come with end links but I also like the Hotchkis kit cause it comes with all the new hardware and stuff but the diameters are quite a bit larger. Any tips? Thanks! Yes I did search first.
FastLane1000 is offline   Reply With Quote
Old 07-11-2013, 07:07 PM   #2
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
OMG the dragon that shit is insane I'd be afraid of crashing you have bigger balls than me sure, I think anywhere between 22-25 MM would be good for you, and just in case a roll cage and 4 point harness for the Dragon I have heard horror stories about the dragon my friend.
Old 07-11-2013, 07:14 PM   #3
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
wut.... its not like the dragon is death road
its just a windy road. its a blast around 55 in most areas. i wouldnt recommend more becuase of the cops everywhere
supramkivtt2jz is offline   Reply With Quote
Old 07-11-2013, 07:27 PM   #4
FastLane1000
Ha, thats funny. I used to drag knees on sportbikes there so I know the road pretty well. Stock, the car is miserable up there with the rear wanting to come out going into every turn. Once you get the car handling neutral with good tires it is very confidence inspiring. My problem last time was just wearing the edges off the tires more than it should cause of the body roll. It could probably use a little more camber too but its my gas saver for commuting and such.
Old 07-11-2013, 07:31 PM   #5
FRSBRZGT86FAN
Yes but I would be much more likely to push myself a bit too far but that's just me
Old 07-11-2013, 09:35 PM   #6
swift996
swift996's Avatar
I've very pleased with my Hotchkis kit, I'd recommend something adjustable so you can play with the different settings and dial in what you want.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 07-12-2013, 09:41 AM   #7
FastLane1000
I've heard a couple people very happy with the Hotchkis kit. What are the advantages/disadvantages with hollow vs. solid bars?
Old 07-12-2013, 10:03 AM   #8
Racecomp Engineering
Our RCE hollow bars will get you an approx 22mm front and 16mm rear with less wight than an equivalent solid bar. Keeps the car nice and flat.
- Andy
Old 07-12-2013, 10:07 AM   #9
ft_sjo
Drives: GT86
Is it roll you're trying to change or improve handling? Why is body roll causing you a problem?
To answer your question, however, if the car understeers then increase the rear bar/reduce front bar spring rate until you get to the feeling you want. If it oversteers then do the opposite.
You may think the car is neutral but it's not. It understeers like a pig (compared to a truthfully neutral car, of which no road cars are). Don't confuse power-oversteer with handling.
I did some rear bar testing and found just going up to a 16mm rear bar over the stock 14mm made a big difference. A 18mm rear bar was too much - you'd need to also increase the front bar maybe 2-4mm to balance the car out and I didn't think it was necessary as body roll wasn't an issue. Depends on your use case though; i'm not racing on a perfectly flat surface, so that will have an effect.
I'm using AD08's by the way, stock suspension.
Old 07-12-2013, 10:11 AM   #10
leon78
leon78's Avatar
Drives: 13 Whiteout
Drive it as is and get more driver-mod. Seat time is your best friend.
2013 Scion FR-S (Whiteout)
GunMetal 16x8+25 Enkei CompE_Cusco OCC_ Kartboy Crank Pulley_Kartboy TMM insert_Koni Yellows_RCE Springs_K&N Drop-In_Eibach FSB_J2 Catless FP_WhiteLine Camber Bolts_NameLess Track Pipe_RBF600_Ferodo DS2500_PTUNING Tuned.
Less parking more racing
leon78 is offline   Reply With Quote
Old 07-12-2013, 02:30 PM   #11
FastLane1000
Leon, I appreciate the bump. I do understand seat time. I've run plenty of 103s at Talladega GP on sport bikes. These cars do get some body roll after adding better rubber. Thats what I'm working on minimizing.
Old 07-12-2013, 02:42 PM   #12
leon78
leon78's Avatar
Drives: 13 Whiteout
I’m more or less preaching to the quire anyhow....I put my FSB in after the first autoX I did with my koni/rce setup on 17x9-245’s...lol
Old 07-12-2013, 02:44 PM   #13
ModBargains.com
ModBargains.com's Avatar
+1
You'll see a lot of Hotchkis everywhere when it comes to sway bars, I mean the company only started business making sway bars only, so you would imagine they're pretty damn good at it. I have Hotchkis bits and pieces on my car, and they're very VERY high quality parts. With the adjustability in the sway bars, you can dial in the exact feel you want to get out of your FRS.
Can't go wrong with Hotchkis for sure. Got great pricing as well if you know the right place to buy from
ModBargains.com is offline   Reply With Quote
Old 07-12-2013, 03:08 PM   #14
ftc~brz
Done
Drives: WRB BRZ
I heart your unicorns!
@ op I too am not sure what way I want to go with this mod so I am curious to see what you decide on. My daily drive is very curvy (no dragon but fun still). Once I beefed up my tires (slight camber in rear) I had more faith at added speeds around them. subed for ideas!
ftc~brz is offline   Reply With Quote
ST Suspensions Lowering Springs & Anti-Sway Bars Now Available @ BMS! Boston Motorsports Brakes, Suspension, Chassis 84 07-23-2013 11:42 PM
ST sway bars bmxhotsauce Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 05-09-2013 03:11 PM
FR-S/BRZ SWAY BARS & STRUT BARS @ NINJA AUTOSPORTS!!! NJA Brakes, Suspension, Chassis 18 04-07-2013 06:00 PM
adjustable sway bars!!! carbonBLUE Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 05-04-2012 08:42 AM
