Old 07-11-2013, 03:30 AM   #1
Bach415
Bach415's Avatar
Drives: Whiteout FRS
Clutch disengage whining sound?
So I'm getting a whining sound from my clutch everytime I disengage it to switch gears(throughout all the gears) around 2-3.5k rpm. Is this normal sound? I don't recall hearing it when I had the car for the first month. I have looked and search the threads and it's not the same sound as the whining/whirring noise in the other thread. My clutch isn't slipping either. I will record a video sometime tomorrow and see if the sound appears in the video.
Bach415 is offline   Reply With Quote
Old 07-11-2013, 11:32 PM   #2
mashal
DADA
mashal's Avatar
Drives: 2013
I have been noticing this also, most when car is cold , once it heats up I can't hear shit over my crickets
mashal is offline   Reply With Quote
Old 07-12-2013, 02:54 AM   #3
Bach415
Bach415's Avatar
This happens when its warmed up as well for me. My crickets start until I rev over 3.5-4k rpm after it being warmed up. Anyone else knows if it's normal or not? Sounds kinda like bees buzzing by your head really quickly then dropping in sound.
Old 07-12-2013, 07:30 AM   #4
whtchocla7e
Drives: 2013 FR-S Hot Lava
Hmm, you should hear crickets at RPM higher than idle, it could be something else..
As for clutch noise, I always had it...
Live to drive another day
whtchocla7e is offline   Reply With Quote
Old 07-12-2013, 08:57 AM   #5
Clembo
'Senior' Junior Member
Clembo's Avatar
Drives: 13 FR-S,08 Mustang Bullitt,06 MX-5
Keep in mind these cars don't have a lot of soundproofing to save weight and cost. You're going to hear things that you wouldn't hear in a luxury sedan. I have driven cheap cars (Corollas, Sentras, etc.) for years so I'm used to it. Buzzing, rattles, whining, clutch mechanicals - I'm used to them all. Not much different in the FR-S so it doesn't bother me much. The boxer engine makes its own unique noises too but I've gotten used to them as well.
I just keep the revs up and that covers up most of it. Unless it's something truly problematic like misfires, skipping, slipping and such, I just ignore the noises and enjoy the car.
"You'll never know if you don't try" - Shinroko Momose
Clembo is offline   Reply With Quote
Old 07-12-2013, 12:05 PM   #6
Bach415
Bach415's Avatar
The crickets are for sure above 3.5-4k rpm cause I usually just cruise on freeways no more than 3k as my limiter is set for 3.5k. The pump has not been replaced by warranty so yeah...
I know the car doesn't have that much sound proofing, it's just the clutch buzzing sound when you disengage the clutch that I remember not having within the first 1.5k miles of the car.
Old 07-12-2013, 12:27 PM   #7
grodenglaive
Drives: asphalt FR-S
That doesn't sound normal, at least I never had any noise from my FR-S clutch. Is that downshifts or upshifts?
The 4-3 shift on my MINI made an awful sound if I didn't rev match, but I never had any transmission problems from it.
grodenglaive is offline   Reply With Quote
Old 07-12-2013, 07:52 PM   #8
Bach415
Bach415's Avatar
It's upshifts only. No issue with downshifts. Tried to record the sound but it didn't show up on the video. Will try again.
whining/whirring noise during high load/rpm clutch engagement 7thgear Issues | Warranty | Recalls / TSB 105 06-19-2017 11:04 AM
Clutch pedal springy sound pdreams Issues | Warranty | Recalls / TSB 16 06-01-2015 02:33 PM
Clunk sound with disengaging clutch up driveway BRRRZZZ Issues | Warranty | Recalls / TSB 4 04-22-2013 08:54 AM
Clutch Cicking Sound KapteinBos AFRICA 9 03-01-2013 05:25 PM
Sound from Clutch KingRohan Issues | Warranty | Recalls / TSB 5 10-17-2012 09:10 PM
