Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AFRICA
Old 02-27-2013, 12:59 PM   #1
KapteinBos
KapteinBos's Avatar
Drives: Toyota 86, Pearl White, Manual
Clutch Cicking Sound
Is it normal? Makes a click when pushing down...
KapteinBos is offline   Reply With Quote
Old 02-27-2013, 01:16 PM   #2
Vic_RSA
The voice of reason...
Vic_RSA's Avatar
Drives: 2012 Toyota 86 6MT Standard
More like a clunk or "cluck" right? I notice what appears to be a thrust bearing noise when lifting the clutch on first start in the morning, has done it since the day I got it.
Maybe just more silicone spray/spook pis necessary...
Vic_RSA is offline   Reply With Quote
Old 02-27-2013, 01:38 PM   #3
KapteinBos
KapteinBos's Avatar
Click / clunk / pop every time i push the pedal down. About half way down. Not loud. Actually quite soft. Can even feel it if i put my hand on the gear knob / lever. Feels like its when the clutch engages... Prob normal im just click befuck at the moment. Boot area still driving me nuts...
Sent from my GT-I9100 using Tapatalk 2
Old 02-27-2013, 01:46 PM   #4
Vic_RSA
Vic_RSA's Avatar
If you don't smell metal burning you should be ok. Take it for a hard burn down some twisty road and work the gears hard, double de-clutch for downshifts and see how it sounds when you get home maybe. But to me it sounds pedal related.
Old 02-27-2013, 03:16 PM   #5
WATIKA
Drives: Gt 86
It's a Subaru clutch thing,nothing wrong with it,they have very mechanical sounds to the clutch,drove an 06 Sti,it had exactly the same noises ans clunky gearshifts.
WATIKA is offline   Reply With Quote
Old 02-27-2013, 04:21 PM   #6
Razzle
Razzle's Avatar
Drives: Toyota 86 (High) - White
Actually it's an aisin gearbox. The same used in the Lexus IS. Toyota owns 30% of Aisin Seiki Co.
Razzle is offline   Reply With Quote
Old 02-27-2013, 04:24 PM   #7
tech4pdx
Make love
tech4pdx's Avatar
Drives: H8R.. Not really
Mine likes to clack, clunk, click, plunk, pop and it even works my leg out. Because racecar.
tech4pdx is offline   Reply With Quote
Old 02-28-2013, 06:29 AM   #8
Thavash
Drives: Red Hachiroku
No clicking at all , but I've noticed this - when I change gear at high revs ( over 5k ) I get a slight vibration on the clutch pedal. Anyone notice this ?
Thavash is offline   Reply With Quote
Old 02-28-2013, 06:33 AM   #9
Naughty
Drives: RunX RSi
Yes i have even at low rpm. Toyota say the GB mounting needs to be re aligned.
After they have done that it all seems to have gone away.
Naughty is offline   Reply With Quote
Old 03-01-2013, 05:25 PM   #10
DrSUTRA
Ayushhealthcare.co.za
DrSUTRA's Avatar
Drives: 86 Hi spec TRD 2013, past C32 AMG
I also noticed the clicking sound...hope its covered by warranty @ TSA....esp if it is not a common toyota thing and more a subaru thing
DrSUTRA is offline   Reply With Quote
Sound from Clutch KingRohan Issues | Warranty | Recalls / TSB 5 10-17-2012 09:10 PM
Special Deals on Clutch Masters Clutch & Flywheel Combo! KronosPerformance Transmission and Driveline 15 08-25-2012 12:22 PM
Clutch Masters Clutch and Flywheel Kits for FR-S and BRZ available at Redline360 Redline360 Transmission and Driveline 2 07-30-2012 10:01 AM
Clutch Masters Clutch Kits | Island Import Performance IslandImportPerformance Transmission and Driveline 1 07-20-2012 12:06 PM
