Old 07-05-2013, 10:51 PM   #1
jonperezinsd
Drives: Subaru BRZ [San Diego 86 Club]
the perfect offset..
i was just wondering what offset is the best withouth starting to rub...thinking about going 18x9.5 +40 but not sure if it will rub...
jonperezinsd is offline   Reply With Quote
Old 07-05-2013, 11:22 PM   #2
Khazzy
Khazzy's Avatar
Drives: SWP Subaru BRZ
http://www.ft86club.com/forums/showthread.php?t=7535
Old 07-06-2013, 05:00 AM   #3
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Fill in the blanks:
- diameter
- width
- type of tire used (specific brand/model)
- is car lowered? how much?
- how much camber?
- what kind of wheel?
etc
Open-ended question = open-ended response. And the other link only semi-helps by assuming you're doing mild spring/shock setup, and/or not slamming the car.
-alex
Old 07-06-2013, 09:54 PM   #4
jonperezinsd
Originally Posted by mav1178 View Post
Fill in the blanks:
- diameter
- width
- how much camber?
etc
-alex
18 x 9.5 +40
not sure which tire i will use..the one that wont rub i guess..lol
car is not lowered..yet..
Enkei NT03+M
Old 07-08-2013, 07:47 AM   #5
dori.
Señor Member
dori.'s Avatar
Drives: white BRZ 6MT
Fill in the blanks:
- diameter
- width
- how much camber?
etc
-alex
18 x 9.5 +40
Enkei NT03+M
you need to really answer all of the above questions.
naturally, the more agressive the offset, the more agressive your drop and alignment have to be.
dori. is offline   Reply With Quote
Old 07-08-2013, 11:50 AM   #6
mav1178
mav1178's Avatar
More importantly, what is your goal for the car?
You need to figure this out first.
-alex
Old 07-08-2013, 01:11 PM   #7
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
18x9.5 + 38 is perfect!
FT-86 SpeedFactory is offline   Reply With Quote
Old 07-08-2013, 04:34 PM   #8
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Not with the stock suspension it isn't.
Old 07-08-2013, 06:34 PM   #9
BRZPDX
Boosted Member
BRZPDX's Avatar
Drives: 2013 SWP BRZ Limited
I have 18x9 +35 with a -2.2 camber, and it is perfect. More camber means more "sink in" by the fender. If you are going without camber, you can get away with less aggressive offsets.
If you are going FI, or more power, you can go for 9.5 in the rears for wider tires, but if you are going just for looks, go 9 with a good spacer.
Suzuki Swift GTI '89, Subaru Impreza L '96, Lancer OZ '03, Subaru Impreza WRX '06, Honda CBR600RR Graffiti, Volvo c30 T5 R '11, Subaru BRZ '13, Audi RS4 2007
SUV's: Mercedes Benz R500 '06, Mercedes Benz ML350 '12
BRZPDX is offline   Reply With Quote
How perfect should tint reasonably be? BlueSTaR Cosmetic Modification (Interior/Exterior/Lighting) 22 06-24-2013 12:04 PM
What offset is legal? What offset provides most benefit? bdohazelnuts Tracking / Autocross / HPDE / Drifting 2 02-08-2013 01:32 PM
The perfect FRS/BRZ ravenblackfrs Scion FR-S / Toyota 86 GT86 General Forum 59 01-22-2013 11:23 PM
Perfect Run? yomchi1989 AUSTRALIA 4 01-13-2013 10:38 PM
perfect car! marine321 Scion FR-S / Toyota 86 GT86 General Forum 65 10-19-2012 02:52 AM
