Old 06-18-2013, 09:21 PM   #1
Splat
Drives: FR-S ultramarine
DIY -my scanguage placement
I got the scanguage2 for oil temps, water temps and transmission temp.. Well, no luck getting trans temp yet. Rest is all good and has volts, and few other items.
I have mine reading oil, water, HP, and Throttle. Seems to do well.
I have seen a few others post their placement, this is mine. I put it at an angle, for easy viewing.
Understand, this is to big to just go into the unit by about .100 or 1/8th", and yes that takes into consideration removing the rubber bottom.
Many redundant pics, but goes with the flow.
Splat is offline   Reply With Quote
Old 06-18-2013, 09:22 PM   #2
Splat
acces tray has rubber flap that is just double backed tape. Pull it out.
Old 06-18-2013, 09:25 PM   #3
Splat
Next take off the side covers. Reach behind and push out the access usb port and disconnect.
Old 06-18-2013, 09:26 PM   #4
Splat
Now you have some leverage to use and pull this out of its cubby.
Old 06-18-2013, 09:28 PM   #5
Splat
Take the plastic box and drill a 5/8ths hole in center rear of the box.
This is for the scanguage cable.
Old 06-18-2013, 09:29 PM   #6
Splat
Attach the USB to obd2 port and route cable thru backside, so that we can run it thru hole drilled in box.
Old 06-18-2013, 09:33 PM   #7
Splat
I also am doing my phasetek footwell lighting at same time, connecting all my wires in the box area. I just soldered my wires to the dome assembly, ran them to this box area, then ran both side of lights to the center and soldered them all together.
Back to scanguage- to get my angle I wanted, I used a table saw to notch a 45deg to be able to lock it in place. It is a shallow ledge, you may use dremel or whatever you have.
Old 06-18-2013, 09:39 PM   #8
Splat
Of course attach the cable to the back of the scanguage. You can easily push the extra cable back in.
Next I just added some Velcro tape to the 4 corners of the gauge and the front bottom lip/ top inside lip of the box.
Put the top groove of the gauge into the top of the box, then angle down and make contact with bottom Velcro. Now this puppy is locked in via the groove. You can punch buttons and it is solid.
Here is overall view, showing the gauge at slight angle.
Yes, the doors are open so the floor lighting is on.
Old 06-18-2013, 09:40 PM   #9
Splat
Closer look.
Old 06-21-2013, 10:55 PM   #10
ts87
nice job! giving me some ideas
ts87 is offline   Reply With Quote
Old 06-22-2013, 01:19 AM   #11
YamahaR86
JDM Vaping Stance Nation
YamahaR86's Avatar
Drives: 2013 White
Great job, good alternative for those who need to keep an eye on it but I'm not a big fan of the placement there. It just looks out of place.
Keeping an eye on this for future updates.
YamahaR86 is offline   Reply With Quote
Old 06-23-2013, 09:13 PM   #12
Bt216
Bt216's Avatar
Drives: Scion frs
I got mine right on the steering wheel.. I love it it tells you everything about the car
Bt216 is offline   Reply With Quote
Old 06-25-2013, 07:14 PM   #13
Splat
we sure could use more codes. What do we need to get a transmission temp to come thru?
Old 03-15-2014, 09:50 AM   #14
sirisvirus
Drives:
What OBII SENSOR did you use?
Sent from my Subaru BRZ Limited using plastic cup 2.0
sirisvirus is offline   Reply With Quote
SiriusXm Antenna placement mbh1101 Electronics | Audio | NAV | Infotainment 11 04-07-2014 03:06 AM
Subwoofer placement and car balance denverizzles Electronics | Audio | NAV | Infotainment 8 09-05-2012 10:10 PM
Aftermarket gauge placement CyberFormula Scion FR-S / Toyota 86 GT86 General Forum 22 08-18-2012 01:01 AM
Vinyl Sticker Placement? tintumz22 Cosmetic Modification (Interior/Exterior/Lighting) 13 08-07-2012 05:40 PM
Bluetooth Mic Placement in 86? Aventador87 AUSTRALIA 13 06-11-2012 01:36 AM
