Old 08-05-2012, 02:43 AM   #1
tintumz22
tintumz22's Avatar
Drives: 2013 Scion FR-S Toyota 86
Vinyl Sticker Placement?
I have a personalized sticker made.. but w/c y'all prefer for it to be placed? from the interior? or exterior? I'll be putting it in the rear glass.. i had them made if it is from the interior it can be read.. if it is in exterior? will it get ruined? due to washing?
tintumz22 is offline   Reply With Quote
Old 08-05-2012, 02:56 AM   #2
WolfsFang
Scrape Master
WolfsFang's Avatar
Drives: Goal: Oldest FRS State Side
all my stickers are on the exterior and iv washed my car many times with no problem.
You do realize comparing the BRZ to the FR-S is like comparing which hand you love masterbating too right?
WolfsFang is offline   Reply With Quote
Old 08-05-2012, 10:40 AM   #3
Deebeaux
Deebeaux's Avatar
Drives: i walk the streets.
I've got my own plotter and work with a lot of vinyl. It's always sort of been a hobby/side business for me.
As long as the shop is using a good quality vinyl it should be fine on the exterior of your car. I primarily use a vinyl called Oracal 651, which has a 6 years vertical surface outdoor lifespan for colors (metallics/chrome have much shorter life). I've had stickers on cars for 4 years that still look new. There's only two things I've dealt with that have shortened the lifespan significantly: 1) putting it on a horizontal surface (the roof) and 2) putting it in the path of a wiper blade.
Just ask the shop where you're getting your sticker what the expected outdoor life of the vinyl is. There are plenty of good brands out there: Oracal, Avery, 3M, etc...
This is all assuming a cut vinyl sticker. A solvent ink printed sticker will have a shorter lifespan as the ink fades and wears away from exposure to sun and other elements.
EDIT: I just noticed you said you want to put it on the rear glass. I'd definitely recommend putting it on the outside so you're not risking any chance of damaging the rear defroster. Peeling it off later may remove traces on the window, or if you're using a razor blade and slip you could damage it. Stickers usually get cheaper if you order more than one, so order a couple extra and when it wears out, you'll have some to replace it.
--- Deebeaux
--- Former '13 FR-S Turbo Owner
Deebeaux is offline   Reply With Quote
Old 08-05-2012, 10:59 AM   #4
jschendel
jschendel's Avatar
Drives: 2013 Asphalt FR-S, 94 Rx7, bikes
Yes, I cut my own stickers as well and as long as it was made with decent quality vinyl it will be fine on the outside window. And as deebeaux mentioned above, the standard is Oracal 651.
jschendel is offline   Reply With Quote
Old 08-05-2012, 11:25 AM   #5
sbxjap
sbxjap's Avatar
Drives: '95 Honda Civic HB/'13 Subaru BRZ
Yea, what they said, lol.... Depending on material, exterior is best fo visibility of sticker. Mine have lasted a few years in direct sunlight. Have to be replaced every so often...
sbxjap is offline   Reply With Quote
Old 08-05-2012, 11:33 AM   #6
Deebeaux
Deebeaux's Avatar
It really comes down to quality of material and level of exposure. You can buy more expensive vinyl, Oracal 751 and even 851, but the cost effectiveness is just cut two or three of them in 651 and replace them when needed.
There are plenty of other factors: Do you park in a garage or in the sun all day? How often do you wash your car? Is it in the path of a wiper blade? Where do you live (coast, desert, artic)? All these things and more effect the life of the vinyl. However even in the harshest environment you should get a couple years out of the sticker. At that rate they shouldn't been so expensive it's not worth replacing every 2 years. If they are that expensive, find another shop!
--- Deebeaux
Old 08-05-2012, 07:08 PM   #7
tintumz22
tintumz22's Avatar
Thanks guys! All made me confident puttin on the sticker! I'll just monitor the durability of it and keep everything safe!
Old 08-05-2012, 08:43 PM   #8
Snozzberries
Drives: FR-S Whiteout
Outside every time. It is vinyl, if it gets scrapped up just replace. I have some on my front windshield and they look great on the outside.
Snozzberries is offline   Reply With Quote
Old 08-07-2012, 02:16 PM   #9
markjan1
Drives: honda civic
While cleaning and doing prep work,put the vinyl in a safe place to avoid damage. Just a lil suggestion ...
markjan1 is offline   Reply With Quote
Old 08-07-2012, 02:46 PM   #10
ShoGun
ShoGun's Avatar
Drives: 2013 Subaru BRZ SWP 6MT
anyone know of someone who could make this as a sticker?
http://imgur.com/7HhNG
In white with the inside of the #86 in black?
Or just as a white stick with the black area being "no-sticker"
Im sure we could get 10-15 ppl who want it made as a group buy of some sort
ShoGun is offline   Reply With Quote
Old 08-07-2012, 02:47 PM   #11
driftartist
Kurenai Samurai
driftartist's Avatar
Drives: Red and manual
http://www.sticker-brigade.com/ tell billy that roy sent you. maybe he will give you a deal. he is my friend who has an online store. check him out guys!
driftartist is offline   Reply With Quote
Old 08-07-2012, 03:00 PM   #12
jschendel
jschendel's Avatar
I could but im sure it is a copywrighted/trademarked image. Actually made a few for myself.
http://www.ft86club.com/forums/showthread.php?t=13351
Old 08-07-2012, 03:41 PM   #13
Deebeaux
Deebeaux's Avatar
I can make them as well, but most people, including me, won't touch copyrighted material on a "for profit" basis.
--- Deebeaux
Old 08-07-2012, 05:40 PM   #14
driftartist
Kurenai Samurai
A pirates life for me
FT86Club Sticker MannyO Off-Topic Lounge [WARNING: NO POLITICS] 98 08-20-2014 01:41 PM
Aftermarket gauge placement CyberFormula Scion FR-S / Toyota 86 GT86 General Forum 22 08-18-2012 01:01 AM
Sticker on Windshield DAVE FR-S Scion FR-S / Toyota 86 GT86 General Forum 11 07-22-2012 10:41 AM
Bluetooth Mic Placement in 86? Aventador87 AUSTRALIA 13 06-11-2012 01:36 AM
N1 Spec Visor Sticker GodSays Scion FR-S / Toyota 86 GT86 General Forum 13 03-04-2012 03:22 PM
