Old 06-12-2013, 01:27 PM   #1
Fast_Freddy
Drives: Passat
z
zzz
Fast_Freddy is offline   Reply With Quote
Old 06-12-2013, 01:41 PM   #2
Bullnettles
Drives: Scion FR-S 2013
Header did the most to increase the sound, but I put mine on after I did the cat-back. I highly recommend the stock cat-back if you want quieter; I bought the quietest exhaust I could and it's loud as heck to me.
Bullnettles is offline   Reply With Quote
Old 06-12-2013, 02:02 PM   #3
Bg8780
Bg8780's Avatar
Drives: '13 Black Subaru BRZ Limited
http://www.ft86club.com/forums/showthread.php?t=36467
Some of this info from my old thread might help.
Bg8780 is offline   Reply With Quote
Old 06-13-2013, 08:56 AM   #4
Bullnettles
Originally Posted by Fast_Freddy View Post
So are you running the Q300?
Greddy SP Elite
Old 06-13-2013, 09:35 AM   #5
Gardus@Supersprint
Drives: Clio TCE
You could change the headers and overpipe and keep the stock front pipe with the secondary cat and the rest of the OEM system.
In terms of power increase I have no sure values but my guess is around +7-10 hp of peak power at the crank, probably more than 10 at 6000 rpm.
You'll need to sort out the O2 sensor issue with a microcat/emulator/cheater, with a ECU tune or extending the wire and plugging the sensor after the secondary cat instead of between primary and secondary (you must weld a bung!)
An even better idea is to replace the front pipe with the secondary cat with a sport cat, along with the headers. You'll get the same increase of a full system, low emissions if you go for a good cat and a nice sound increase.
Don't go for a fully decat setup with the stock centre and rear exhaust as it'll be VERY metallic. We've tested this solution and while the car runs fine (no time for dyno testing) the sound is not very good. We're thinking to make a resonated front pipe for this purpose (full decat front section with stock or aftermarket catback)
Gardus@Supersprint is offline   Reply With Quote
Old 06-13-2013, 11:55 AM   #6
Simmons
Simmons's Avatar
Drives: 2024 GR86/ 2015 FRS
This is what I had last week, JDL UEL Header, Perrin over pipe, Perrin front pipe with hfc, and stock cat-back.
It was very quiet, maybe a little louder than stock.
Now I have the same setup but with a Moto-East aluminum axle back(5lbs) It sounds awesome, and saved 21lbs.
Simmons
2024 GR86 71 STR/ 2015 FRS 71 STX
Sponsors Xero-Limit//Karcepts
Simmons is offline   Reply With Quote
Old 06-14-2013, 03:41 AM   #7
Gardus@Supersprint
Drives: Clio TCE
Hi Simmons. Did you dyno the car before and after those mods (without the tune or with the same tune both times)?
I'm skeptical about the advantage of a unequal lenght header kit, aside from the advantage of the removal of the primary cat.
Old 06-14-2013, 06:54 AM   #8
Simmons
Simmons's Avatar
I had a couple dyno's of the car with everything except the header, then the finale one with the header. It made a big difference, no more tq dip.
Simmons
Old 06-14-2013, 07:50 AM   #9
Gardus@Supersprint
Drives: Clio TCE
Charts?
Old 06-14-2013, 11:25 AM   #10
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
This is the greatest header info I've heard. Sound like exactly what I'm looking for
Join the Galaxy Blue Silica BRZ registry below:
https://docs.google.com/spreadsheet/...2c&usp=sharing
Laika is offline   Reply With Quote
Old 08-09-2013, 08:38 AM   #11
Rampage
Senior Member/Old Fanboi
Rampage's Avatar
Drives: 2000 2ZZ-GE MR2 Spyder HT
Okay, I received my Tsudo catted front pipe from Jon Motoring and it is a true objet d'art. Much prettier TIG welds than any other front pipe I've seen yet and 304SS polished to perfection. Perfect fitment, 200 metallic substrate cat and 1/2" thick, perfectly flat flanges. Jon Motoring even included a 304 SS L-shaped O2 spacer much like one sold by Weapon-R for $60. All this for $170 with free shipping? WOOT!!!
Price on the website seems to be $200?
So many modders have more cents than sense!
Rampage is offline   Reply With Quote
Old 08-09-2013, 01:29 PM   #12
Aaron_blatherwick
You really should get some sound clips up, that is exactly the set up I am wanting to do also, I have decided to do the muffer last if at all. The header and hi flow cat front pipe will be first. I want the real nice sound and the hp gain in the torque dip from the uel header, but I think with cat back it might be too loud for what I'm looking for. I don't want people to hear me coming from a mile away as I drive spirited on their lake road. I'm really wanting to try and get the rev works header but the price of borla is hard to pass up, as long as they hold up on their end for warranty issues.
Aaron_blatherwick is offline   Reply With Quote
Old 08-14-2013, 04:22 AM   #13
Fast_Freddy
Drives: Passat
I'm going to a dyno today. I'll have sound clips and dyno sheets soon. Maybe even a before and after tune comparison.
Old 08-14-2013, 08:13 AM   #14
DarkSunrise
DarkSunrise's Avatar
Awesome keep us posted.
2022 BRZ Build
2013 FR-S Build
Stock header .. Mikem53 Engine, Exhaust, Transmission 25 09-23-2016 10:50 AM
SRT Header back exhaust? Danny Engine, Exhaust, Transmission 23 04-07-2014 08:29 PM
Borla UEL Header, Full Catless exhaust, Stock Midpipe, Berk Muffler Delete evilconcarne999 Engine, Exhaust, Transmission 34 03-24-2014 01:39 PM
Borla UEL Header and Stock Exhaust CEL 01s0uljah Engine, Exhaust, Transmission 23 05-30-2013 04:45 PM
WTB, stock header-back exhaust. Vancouver/Lower Mainland, pick up. Dimman Canada Classifieds 6 11-18-2012 03:01 PM
