Old 05-19-2013, 06:46 PM   #1
01s0uljah
Drives: SWP Subaru BRZ Sport-Tech 6AT
Borla UEL Header and Stock Exhaust CEL
Hey guys,
There's plenty of you guys out there with the Borla UEL headers and aftermarket exhaust systems, how'd you guys get around the CEL without a tune?
I ordered the Borla UEL headers and planning to run it with stock everything else for now, without a tune until my wallet agrees to pay for a tune.
01s0uljah is offline   Reply With Quote
Old 05-19-2013, 06:48 PM   #2
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
well you should've searched, but considering you already created this thread.
You should add a defouler / O2 sensor spacer that ends up tricking the sensor.
Old 05-19-2013, 06:53 PM   #3
DJCarbine
Thupercharged
DJCarbine's Avatar
Just let the CEL be on until you get a tune. Only downside is no cruise control.
Its not worth removing the underpanel and doing defoulers if you are getting a tune.
Old 05-19-2013, 07:30 PM   #4
SmsAlSuwaidi
Boosted
considering his doing the headers, removing the under panel could be done with it
Old 05-19-2013, 08:03 PM   #5
Mtlrick
Mtlrick's Avatar
Drives: Whiteout FR-S
I bought a Weapon-R o2 sensors ! 55 bucks.
Mtlrick is offline   Reply With Quote
Old 05-19-2013, 09:52 PM   #6
FR-S Matt
Budget a tune with the headers if possible.
Old 05-19-2013, 10:08 PM   #7
Mtlrick
Mtlrick's Avatar
next summer , I'll get a tune :P
Old 05-19-2013, 11:19 PM   #8
frslee
Just drive it
Drives: 13' FR-S
So.. no cruise control with catless header?
frslee is offline   Reply With Quote
Old 05-20-2013, 12:35 AM   #9
TheSlickOne17
Drives: 07 scion tc 06 Evo 9 mr 10 4runner
eBay o2sensor spacer.
5 bucks.
Check the ECS motorsports borla header group buy
TheSlickOne17 is offline   Reply With Quote
Old 05-20-2013, 02:24 AM   #10
Fast_Freddy
Drives: Passat
I see no reason for a CEL as long as the secondary cat is left intact. The CEL is only triggered when the post-secondary cat O2 sensor reads too much oxygen because there are no upstream cats. If for some odd reason you do get a CEL for reduced catalyst efficiency a simple anti-fouler/CEL eliminator on the secondary O2 sensor should eliminate the CEL.
Do consider that the cheap anti-foulers are zinc plated mild steel that will rust very quickly and be impossible to remove later on should you need to replace the sensor, etc. IMO it's worth a few dollars to get one in 304ss. Also the angled versions seem to work better than straight ones.
Fast_Freddy is offline   Reply With Quote
Old 05-20-2013, 02:48 AM   #11
ft_sjo
Drives: GT86
There is no 'post secondary cat o2 sensor'.
Old 05-21-2013, 02:58 AM   #12
Fast_Freddy
Drives: Passat
So where is the secondary (narrow band) O2 sensor installed? Is it after the primary cat but before the secondary cat? If so, a CEL eliminator should still work.
Just remember that whatever you do, NEVER PLACE A ANTI-FOULER ON THE PRIMARY (WIDE BAND) O2 SENSOR!!!
Old 05-21-2013, 03:07 AM   #13
ft_sjo
Drives: GT86
It's immediately after the primary cat.
Old 05-22-2013, 11:34 AM   #14
crizkay
crizkay's Avatar
I'm new to the whole header/cats game...would something like this on the Borla UEL trick the sensor?
http://www.ebay.com/itm/STAINLESS-ST...13a128&vxp=mtr
crizkay is offline   Reply With Quote
Borla Header with test pipe and ISIS exhaust post_break Engine, Exhaust, Transmission 12 05-24-2015 10:43 PM
Borla UEL Header, Full Catless exhaust, Stock Midpipe, Berk Muffler Delete evilconcarne999 Engine, Exhaust, Transmission 34 03-24-2014 01:39 PM
quick vids borla uel header custom exhaust 1 1/4 inch piping HI Engine, Exhaust, Transmission 12 04-19-2013 07:06 AM
BORLA UNEQUAL LENGTH HEADER NOW IN STOCK @ NINJA AUTOSPORTS!!! NJA Announcements, Contests, Giveaways 6 04-03-2013 05:47 PM
In Stock: Borla FR-S/BRZ Lightweight Cat Back Exhaust! 10k Redline Engine, Exhaust, Bolt-Ons 8 10-23-2012 03:11 AM
