Old 05-21-2013, 08:49 AM   #1
Mikem53
Drives: FR-S 6MT
Stock header ..
Just wondering how restrictive the stock header is.. I know there are lots of aftermarket ones available.. But I haven't seen what the stock one looks like..
It's got the heat shielding everywhere and it looks like a pancake.. Anybody seen one without all the shielding?
And is the shielding necessary to protect the other components nearby.. ?
The last car I put headers on was my 94 LT1 camaro.. I had them ceramic coated to keep the heat down.. Wrapping them caused them to crack..
That's was some time ago.. And I'm out of touch.. You all are making me feel old and slow with my stock FRS.. Thanks in advance..
Mikem53 is offline   Reply With Quote
Old 05-21-2013, 08:57 AM   #2
ft_sjo
Drives: GT86
I doubt the design is that terrible; the most restrictive part is probably the cat. Yes the heat shields will be to protect the components around it.
Old 05-21-2013, 09:05 AM   #3
Mikem53
Drives: FR-S 6MT
I know why the heat shields are there.. I was referring to the aftermarket pipes that aren't heat shielded .. How that will affect the durability of the surrounding components.. Hoping to see a naked stock header pic... Thanks
Old 05-21-2013, 09:15 AM   #4
vtmike
vtmike's Avatar
Drives: Scion FR-S
The big advantage of going with a header, equal length specifically, is if designed right they have been shown to remove the torque dip.
vtmike is offline   Reply With Quote
The Following 2 Users Say Thank You to vtmike For This Useful Post:
Mikem53 (05-21-2013), niceguy21 (05-21-2013)
Old 05-21-2013, 09:18 AM   #5
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
UEL headers will do the same thing, and then some. Still n/a, too, just with an E85 tune.
Torque dip turned to torque bump, specifically a better looking bump than any EL header has dyno'd previously on these cars.
The Following 2 Users Say Thank You to ATL BRZ For This Useful Post:
Mikem53 (05-21-2013), Tujin (05-21-2013)
Old 05-21-2013, 09:40 AM   #6
FR-S Matt
The header by itself won't really solve the dip issue, but a tune along with the header is where you see the largest gains. Can't go wrong with UEL or EL. Both are producing great numbers, but the EL offers options like catted on certain ones and interchangeable V-band clamps to convert to a turbo manifold from NA. I prefer the sound of the UEL though.
Old 05-21-2013, 10:15 AM   #7
Kodename47
Kodename47's Avatar
Drives: UK GT86
A tuner local to me is going to remove the cat in the stock header and replace it with a decat pipe. Hopefully will have the results soon.
.: Stealth 86 :.
Kodename 47 DJ:
The Following User Says Thank You to Kodename47 For This Useful Post:
LeeMaster (05-21-2013)
Old 05-21-2013, 10:31 AM   #8
vtmike
vtmike's Avatar
Drives: Scion FR-S
P&L torque curve looks better to me. A tune does really help out though.
Old 05-21-2013, 10:37 AM   #9
ATL BRZ
ATL BRZ's Avatar
P&L EL on E85
JDL UEL on E85
It's pretty obvious the JDL has a better, flatter torque curve from 2000 rpms on and 9 more ft/lbs peak torque...
Back on topic!
The Following User Says Thank You to ATL BRZ For This Useful Post:
ngabdala (05-21-2013)
Old 05-21-2013, 10:40 AM   #10
vtmike
vtmike's Avatar
Drives: Scion FR-S
That's a different dyno than the one they have posted now.
Only thing I'm looking at is shape. Different dynos get different numbers.
Old 05-21-2013, 10:47 AM   #11
ATL BRZ
ATL BRZ's Avatar
Same peak TQ numbers on both dynos from P&L. Those are the exact same dynos, just the one in their advertisement has smoothing applied to it to make it look better for the ad. They also dont start the E85 tune torque line until 3200 rpms....
The JDL is already making more torque at the same 3200 rpms spot where the P&L E85 dyno begins.
Old 05-21-2013, 10:57 AM   #12
vtmike
vtmike's Avatar
Drives: Scion FR-S
I see now they have the same numbers.
The uel looks good. Are they able to keep the same general shape of the torque curve on pump gas? I personally would rather have the option to have a cat.
I still wouldn't trust absolute numbers between 2 different dynos. I'm sure the P&L was done on a different dyno than the uel car.
Old 05-21-2013, 11:00 AM   #13
ATL BRZ
ATL BRZ's Avatar
Well nobody has dyno'ed the JDL UEL header on a a 93 oct pump gas tune yet, but very soon @moto-mike will be doing one on an otherwise stock car. I think at least 190whp is agreeable tuned on pump gas, but Mike has said in other threads he thinks that 200whp on pump gas is doable with the right supporting mods!
Old 05-21-2013, 11:09 AM   #14
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
Since you seem insistent on taking shots, The JDL dyno as I've pointed out to you before, but you choose to ignore, includes an intake, while the P&L dyno does not giving you better numbers. There is also another dyno using the catted version that starts sooner.
Additionally, those dynos were taken after only a few e-tunes. Their intent was to show that the Header makes significant gains. My car was tuned due to a limited schedule, and it had to come off the dyno so I could get to work. Meanwhile the JDL dyno was made by a quality tuner who got to spend a lot of time with the car getting the tune perfect.
Lastly, as I've pointed out to you before as well, my baseline starts at 160 ending at 198.81. The JDL starts at a much higher baseline
It's good that you're rooting for JDL and all, I root for P&L, but I also don't badmouth other vendors while I do it, and let the product stand for its self.
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Borla UEL Header and Stock Exhaust CEL 01s0uljah Engine, Exhaust, Transmission 23 05-30-2013 04:45 PM
BORLA UNEQUAL LENGTH HEADER NOW IN STOCK @ NINJA AUTOSPORTS!!! NJA Announcements, Contests, Giveaways 6 04-03-2013 05:47 PM
Stock Header Question wootwoot Engine, Exhaust, Transmission 12 12-24-2012 05:24 PM
Horrible Stock header? brichard0625 Engine, Exhaust, Transmission 5 12-03-2012 11:25 AM
WTB, stock header-back exhaust. Vancouver/Lower Mainland, pick up. Dimman Canada Classifieds 6 11-18-2012 03:01 PM
