dying bird under the hood
Drives: 2013 SWP Limited BRZ
Strange noise at 2500 RPM
I'm getting a strange grinding noise noise everytime I pass 2500RPM in any gear, is anyone else having an issue like this? it only happens between 2500-2600 RPM.
current mods are uel headers, full header back, perrin drop in and tune.
Grip>Slip
Video would help
Drives: 2013 Black FR-S
Sounds like you have an exhaust frequency at that RPM that is vibrating something like a heat shield or a loose bolt or etc. It is probably the exhaust considering that is what you changed out.
Drives: 2012 Toyota 86
thats my guess as well. alot of people have had a problem with the heat shield over the stock muffler area.
I'm going to agree with these other genius's here. I am pretty sure it has to do with the exhaust system upgrade (a video or sound clip would help by the way). A lot of people complained about squeaks and grinds after full exhaust or catback exhaust upgrades, meaning something can take the extra vibrations or noise and just decides to rattle away. Also does this happen at a stand still in neutral? it could help you to diagnose the location of the rattle/grind. I wouldn't doubt there's a fix on here somewhere because you are not the only person with this issue. Also where exactly does the sound emanate from?
everyone on here will be sure to help you out
Grip>Slip
maybe a rattle, but i've never heard an exhaust cause anything close to what I would describe as a "grind" like OP described.
ive heard a very distinct grinding noise caused by some exhausts and the oem heat shield over the muffler. theres a youtube video of it somewhere, but im having trouble finding it.
edit: found it. [ame="http://www.youtube.com/watch?v=cujLV7coC1I"]frs j2 exhaust quad tip - YouTube[/ame] |
Drives: DGM BRZ 6MT
I sometimes hear a metal rattle/grind on my car (all stock) at around 1.5-2k on lower gears, but I thought maybe i'm just lugging the engine and just shift at a higher RPM now.
| Strange Noise from rear of car while OFF | mike2100 | Issues | Warranty | Recalls / TSB | 23 | 12-17-2014 08:14 PM |
| Strange Tapping noise from under car after use | rhood168 | Issues | Warranty | Recalls / TSB | 10 | 02-12-2013 02:16 AM |
| Strange noise at 2k RPMs | Cajun | Issues | Warranty | Recalls / TSB | 3 | 11-29-2012 10:30 PM |
| BRZ/FRS automatic owners ... Strange noise | Delacruzmd | Issues | Warranty | Recalls / TSB | 6 | 10-16-2012 07:16 AM |
| Strange noise | Random_Art | Other Vehicles & General Automotive Discussions | 15 | 06-03-2011 03:31 PM |
