Old 03-18-2013, 11:10 PM   #1
Tiremonkey0824
Drives: 2013 Argento 6mt
Led dome light issue with heat
Anybody else with an led interior dome light having issues when it gets warm outside? It's been pretty warm in texas the past week and my dome light keeps un-sticking from its position in the light housing. It's attached with a 3m type adhesive.
Tiremonkey0824 is offline   Reply With Quote
Old 03-19-2013, 07:01 PM   #2
jjdrivesajazz
Drives:
you shouldnt have any issues with it as long as the surface it was mounted on was cleaned and prepped before sticking, sometimes the plastics have a slick film on it, a quick wipe with a quick detailer or alcohol pad gets rid of this, that's what i usually do and i've never had an issue with it falling off or coming loose
jjdrivesajazz is offline   Reply With Quote
The Following User Says Thank You to jjdrivesajazz For This Useful Post:
Tiremonkey0824 (03-19-2013)
Old 03-19-2013, 08:46 PM   #3
Tiremonkey0824
Thanks I'll try this and see if the issue persists.
Map/Dome Light Dis-assembly/Phastek Performance LED Dome Light F1point4 DIY (Do-It-Yourself) Guides 9 03-25-2014 10:39 PM
Replace Dome Light Zoomryder Cosmetic Modification (Interior/Exterior/Lighting) 6 04-09-2013 06:54 PM
Dual Color Dome Light boredom.is.me Electronics | Audio | NAV | Infotainment 2 01-13-2013 01:40 PM
LEDs that convert heat directly into light... serialk11r Off-Topic Lounge [WARNING: NO POLITICS] 12 03-10-2012 01:08 PM
