Old 05-24-2013, 12:18 PM   #1
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
AT fluid metal shaving?
This post is primarily asking about the amount of metal shaving in the automatic transmission fluid vs other components.
Does the automatic transmission have much metal shaving during the break-in period? I heard people reporting quite a bit of metal shaving in diff fluid during the first couple thousand km or miles. Do you think that'll be the case for the AT fluid?
i'm gonna get my engine oil and diff oil changed, wondering if i should get my AT fluid changed as well? It looks like changing the AT fluid is a bit more work than MT fluid. I have about 4800km(3000 miles) lots of heavy traffic driving.
chenshuo is offline   Reply With Quote
Old 05-24-2013, 06:32 PM   #2
Mikem53
Drives: FR-S 6MT
Your will get some metalic paste on the magnetic drain plug.. From the clutch packs.. You don't have gears per say.. Most autos use a planetary gear set.
So you don't need to change it out early. I just did a change on my wife's car after 60K miles.. Looked fine.. Just the normal accumulation of paste on the plug.. I would leave it be..
Mikem53 is offline   Reply With Quote
Old 05-24-2013, 06:34 PM   #3
Wo6M
Keep Calm And Drift On~
Wo6M's Avatar
Drives: Scion FR-S WhiteOut 6 Speed Manual
I agree.
2013 Scion FR-S White Out Six Speed Manual
Mods:
Wo6M is offline   Reply With Quote
Old 05-24-2013, 08:28 PM   #4
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
Depending on your driving style, I would consider a B&M ATF Cooler in conjunction with Redline High Temp ATF. Very Very effective in protecting your AT. We built a road race impreza with an AT and used this setup on a car that started with 120k miles on the ticker. When we sold it we had put on about 50k track miles and the trans was still running well. We did the equivalent of a 7 hour enduro with it at Watkins Glen during one of our race/DE weekends.
If you don't drive it very aggressively or sit in a lot of traffic, wait until the 30k major service and just do a drain/fill with the RL High Temp ATF at that point.
-Mike Paisan
AZP's First Private Track Event, June 19 at NJMP Thunderbolt $315 including Classroom and Mentor!
11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts.
Call directly as We carry almost every manufacturer now, so before you buy parts call us.
Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) | T-1 Certified Amsoil Direct Jobber |AIM: AZP Installs
"Race Tested, Enthusiast Approved!"
AZP Installs is offline   Reply With Quote
DOT4 Brake Fluid Change and ABS Black Tire Tracking / Autocross / HPDE / Drifting 4 04-20-2013 06:24 PM
tranny fluid change Dispect Engine, Exhaust, Transmission 3 01-27-2013 11:31 AM
MT fluid change experience Brzer Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 18 12-16-2012 02:25 AM
Fluid change siXXtoes Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 12-06-2012 09:39 AM
500 Mile - Complete fluid change Touge Factory Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 42 11-07-2012 04:10 PM
