Old 04-19-2013, 06:22 PM   #1
Black Tire
Black Tire's Avatar
Drives: Whiteout Scion FR-S
DOT4 Brake Fluid Change and ABS
After a move last year, I don't have many track/race experienced mechanics in my area, so I thought I'd ask about changing brake fluid.
I need to change the stock DOT3 fluid to DOT4 fluid for the track. My mechanic did not know if the FR-S required a release of the ABS system to completely flush the old DOT3 fluid. Does anyone know if this is an issue? Does the clutch need to be cycled at the same time because it uses the same fluid and reservoir?
Old 04-19-2013, 06:40 PM   #2
Wait wut?
We just did a "normal" bleed and we've been fine... I wasn't aware there were extra steps (and if they were taken, I'm unaware of that as well)
Old 04-19-2013, 06:58 PM   #3
renfield90
The Stig's German cousin
A normal bleed will suffice. DOT 3 and 4 don't have any harmful interactions with each other. I don't happen to know if the clutch uses the same reservoir though.
Edit: I see what you're asking. I believe someone posted a pdf of the factory service manual, this question should be answered in there.
Old 04-20-2013, 10:40 AM   #4
THEmailman
Drives: Raven 6MT
I have seen this before but only on older cars (90 300zx and an early c5 vette). Those ABS modules looked very different than the one in our cars though. I searched around and couldn't find an answer so I just did a normal bleed. If you do find out let us know. And the clutch and brake cylinders are separate so you can drain the brakes without affecting the clutch.
Goodridge SS brake lines//ProjectMu 999's//Motul DOT 5.1 brake fluid//GrimmSpeed master cylinder brace//Jackson Racing Oil Cooler//Whiteline camber bolts//Raceseng CamCas plates//Kosei K4R 17x8//BFGoodrich Rivals 225/45
THEmailman is offline   Reply With Quote
Old 04-20-2013, 06:24 PM   #5
xwd
It should be in the manual. On even recent Subaru ABS models it was sometimes necessary to cycle the ABS pump to properly bleed the brakes, although I never ran into issues with not doing it on my WRX.
Automatic Transmission Fluid Change jmaryt Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 169 08-26-2018 07:55 PM
tranny fluid change Dispect Engine, Exhaust, Transmission 3 01-27-2013 11:31 AM
MT fluid change experience Brzer Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 18 12-16-2012 02:25 AM
Fluid change siXXtoes Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 12-06-2012 09:39 AM
500 Mile - Complete fluid change Touge Factory Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 42 11-07-2012 04:10 PM
