Drives: BRZ, 2011 Outback 3.6R
MT fluid change experience
I know that there have been a lot of posts about MT fluids but after reading all of them as well as posts on Bobistheoilguy, I decided to go with GM part #12346190. It is a fully synthetic Gl-4 made with with PAO's and esters and no pseudo-synthetic GroupIII oil and variably described as a 75w-90 and 75w-85 with KV40 and 100 values of 75 and 11.5 cSt. In the Chevrolet 2010 vehicle product car manual it is described as a 75w-90, so no warranty issues using it. It is expensive. Retails for 26.36 a quart. I got it at dealer cost for 16.53. Shifts are now very smooth with just the right engagement feel and no second gear notchiness! Highly recommended. See link for warranty proof of Gl-4 and 75w-90. The second option is the one to download.
http://printfu.org/gm+oil+12346190 |
Update after driving in weather in the 30s, mild second gear notchiness briefly. Still much better than OEM. May try Pentosin next time but not until my warranty is up. I don't want a claim denial.
What makes you think running pentosin will be a claim denial?
It is a 75w-80 and the manual calls for a 75w-90. I am not concerned that it wouldn't be a good choice, but if I where to have bad luck with my transmission, Subaru could use this as a way to deny warranty.
Given the dealer techs cant even tighten lug nuts right, last thing I would worry about is them sending trans fluid to a lab to test oil weight.
Subaru product specialist
Drives: BRZ Sportech
Pentosin MTF2 is definitely working perfectly for
my BRZ transmission, smooth like butter without compromise. Car is almost at 8000 clicks and temperatures since flush 2 weeks ago are 20 to 50F. |
Is this something that can be easily done by an average at-home garage tinkerer (with basic tools), or should it be done by a transmission shop? How many quarts are required? I think this will be one of the first things I do once I get my FR-S in the spring!
Ultramarine 2013 Scion FR-S 6MT
Looks similar to my old STI. If you can do an oil change, should be no problem.
#9 | |
easy to do for home wrench, depending on your skill level, if you can change engine oil and get the car up safely you can do this too |
#10 | |
Site Moderator
Drives: Stuff
4 jack stands, a jack, a couple of tools, crush washers (or reuse, I prefer to replace), fluid pump (unless using gear 300 in the trans), and some tools. There's a DIY in the DIY subforum.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#11 |
Site Moderator
Drives: Stuff
He's using pentosin mtf2 now I believe...
-Dave
#12 |
Drives: 2013 scion frs Whiteout
#13 |
use a big shop type fluid syringe, its cleaner than most screw on pumps.
#14 |
Where can you get one of those? I've looked for something just like that before with no luck
| DIY - Transmission / Diff Fluid Change Reference Guide | F1point4 | DIY (Do-It-Yourself) Guides | 295 | 05-13-2023 02:34 AM |
| 1st Oil Change Experience, Observations & a Surprise | Black Tire | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 100 | 09-14-2015 09:23 PM |
| What Differential fluid is in your BRZ/FRS? | ft86Fan | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 9 | 11-12-2012 08:57 PM |
| Track Day Brake Fluid | Skorov | AUSTRALIA | 2 | 11-11-2012 07:10 PM |
| 500 Mile - Complete fluid change | Touge Factory | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 42 | 11-07-2012 04:10 PM |
