Old 05-21-2013, 02:44 AM   #1
BRAWL
Drives: Toyota 86 GTS Velocity Orange
Borla UEL headers w/stock exhaust VIDEO
[ame="http://www.youtube.com/watch?v=7ZM5d_7c5Xo"]Borla UEL headers with stock exhaust - YouTube[/ame]
Had them installed yesterday by Peter at Exhaust World in North Perth who did a great job. I provided spacers for the O2 sensors (HELP 42009 spark plug non-foulers) which have (so far at least) stopped the CEL issue from having no cat.
The torque dip is more like a plateau now and seems to pull a lot better, but let's face it, the main reason for UEL is boxer rumble!
Not sure on what to do for the rest of the exhaust but it is likely that it will be an Invidia Q300 and then a custom down and midpipe
BRAWL is offline   Reply With Quote
Old 05-30-2013, 09:04 PM   #2
BRAWL
I will post up another video after a month or so if there is any change to the raspy start up noise. I suspect it will quiet down on start up after it has got a bit of carbon in there
On a cruise recently I opened her up at freeway speeds and will post up the in cabin video of that shortly
Old 05-30-2013, 09:19 PM   #3
Adeets
OEDC
Adeets's Avatar
Drives: Vortech 8.5psi 274WHP 2013 BRZ
There's not, that's your car warming up. Keeps the weird rasp on every warm up.
My BRZ FI Build
Visconti is like a Tick that sucks as much blood(money) as he can before you figure out he's there.
please make sure to leave your experiences with visconti on his feedback thread located here: Visconti feedback
Adeets is offline   Reply With Quote
Old 06-07-2013, 03:18 AM   #4
Fast_Freddy
Drives: Passat
Never put a spacer/anti-fouler on the primary wide-band O2 sensor! The ECU relies heavily on this sensor to adjust the AFR. The secondary O2 sensor is the one that monitors catalyst efficiency and requires attenuation when the primary cat is removed.
Fast_Freddy is offline   Reply With Quote
Old 06-10-2013, 09:39 PM   #5
BRAWL
A CEL will be thrown othewise. Until I tune the engine this will be the solution. 1000km and no issues so far
Old 06-10-2013, 11:17 PM   #6
Bach415
Bach415's Avatar
Drives: Whiteout FRS
The exhaust in the video doesn't look stock. Did you mean headers with stock overpipe/frontpipe/midpipe and axleback?
Bach415 is offline   Reply With Quote
Old 06-10-2013, 11:29 PM   #7
m.box.design
m.box.design's Avatar
Drives: 2013 Whiteout FRS
he's from australia, they get the 86mm tips.
Old 06-11-2013, 03:34 AM   #8
Bach415
Bach415's Avatar
Ahhh I see. Didn't know that :/. Wouldn't that make a big difference in terms of sound/drone/raspy/etc comparing it to ths US 86?
Old 06-11-2013, 04:13 AM   #9
Fast_Freddy
Drives: Passat
Good luck with the "lean burn" AFR mod. The hydrogen fuel cell and high MPG guys are pretty big on this mod too. Just be careful that you don't let your EGT get too high while running such a lean AFR or you might melt a piston. You will lose power this way but gain mpg so if that's what you're after, good luck with it.
Old 06-11-2013, 04:19 AM   #10
LivingLegend
Drives: 1994 Toyota Tercel
Woah I thought I was in a game of COD when the car started lol.
LivingLegend is offline   Reply With Quote
Old 06-11-2013, 11:43 AM   #11
Fett4Real
AKA Mugen Dom
Fett4Real's Avatar
Drives: 2013 FR-S, 2007 FJ Voodoo Blue
This....
Put the sparkplug defouler on the O2 AFTER the Cat...not before. Even if you throw a code for the Cat you wont run lean.
Fett4Real is offline   Reply With Quote
Old 06-11-2013, 05:28 PM   #12
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
It's hard to tell from the video; how much louder did the car get vs. stock?
l0aded is offline   Reply With Quote
Old 06-12-2013, 06:37 PM   #13
BRAWL
It got a little louder, but mostly under load. When idling it seems to be quite normal but can still make out that rumble
Old 06-12-2013, 09:02 PM   #14
Vegas Racing
Sounds really good.
Vegas Racing is offline   Reply With Quote
Borla UEL Header and Stock Exhaust CEL 01s0uljah Engine, Exhaust, Transmission 23 05-30-2013 04:45 PM
Anyone have a Borla UEL headers with Invidia Q300 Exhaust video/sound clips Eurasianman Engine, Exhaust, Transmission 17 03-21-2013 01:15 PM
headers w stock exhaust DanoFA20 Engine, Exhaust, Transmission 4 02-01-2013 06:41 PM
In Stock: Borla FR-S/BRZ Lightweight Cat Back Exhaust! 10k Redline Engine, Exhaust, Bolt-Ons 8 10-23-2012 03:11 AM
What you guys do with stock headers and exhaust after swap? WatchmaN Engine Swaps 6 08-09-2012 06:26 PM
