Old 05-20-2013, 02:11 PM   #1
taimysho0
Drives: frs
Radio Flickers on Turn Signals
hi, i bought my car used with leds installed for the turn signals/switchbacks. i noticed intermittently, the radio screen flickers in sync with the turn signals. i installed a relay thinking this would fix the hyperflash and radio flickering issue, but it did not. it only resolved the hyperflash. im already planning to buy an aftermarket double din, and hoping this issue wont transfer over to the double din, but anyone experience this>? thanks
taimysho0 is offline   Reply With Quote
Old 05-20-2013, 02:16 PM   #2
spgrizz22
Drives: Scion FR-S
Dude! My radio signal messes up when I turn on my headlights! All I hear is static!
spgrizz22 is offline   Reply With Quote
Old 05-20-2013, 05:34 PM   #3
taimysho0
Drives: frs
crazy^. yea another thing is when i unlock my car with my key, my DRL led turns on, but only one side. but when i turn on my car, both DRL led's work fine??
Old 05-20-2013, 06:02 PM   #4
DoomsdayJesus
In Autobahn withdrawl
DoomsdayJesus's Avatar
Drives: 2015 BRZ Limited Man., WRB
A lot of aftermarket LED lights will do this, especially with AM radio. LED lights are not electromagnetically shielded, and some emit RF "pollution" or interference. You may notice that it's worse in the early morning than it is during the daytime when signals are stronger.
As for the hyper flash, don't mess with resistors. Simply buy an LED compatible LED flasher relay to replace your stock one. In anticipation of doing my own I just got a relay with an adjustable flash rate knob on it from iJDMtoy.com on Amazon. That'll fix all of your hyperflash problems. I did the same thing on my Subaru Outback, which uses the same flasher relay.
Back to the radio: One thing I have yet to try is to get some of those removable EM barrier things that clips around the wire harness to the lights. You typically see them on USB cables for PC components, this may be a partial solution to the RF interference. They have some sort of graphite or similar looking material that surrounds the wires.
Edit: to answer your other question, this will transfer to any other radio since it's the antenna picking up the interference.
DoomsdayJesus is offline   Reply With Quote
Old 09-17-2013, 08:03 PM   #5
Mikegraves777
Drives: 2013 Scion FRS
Mine does the same thing with new led blinkers radio blinks but only when blinker and brakes are applied together soon. As I let off brakes it's fine
Mikegraves777 is offline   Reply With Quote
Old 09-17-2013, 08:32 PM   #6
Dan@AWD
Drives: 2013 Argento FR-S
This happened to me. My switchback's were backwards and now it is fine.
Dan@AWD is offline   Reply With Quote
DIY JWMotoring LED turn signals sirhc DIY (Do-It-Yourself) Guides 54 03-16-2013 03:22 PM
Eyebrow Turn Signals PhastekSport Cosmetic Modification (Interior/Exterior/Lighting) 11 01-28-2013 01:52 AM
Custom turn signals? benlevy3 Cosmetic Modification (Interior/Exterior/Lighting) 2 11-01-2012 03:23 PM
Need help with LED turn signals. Khalis Cosmetic Modification (Interior/Exterior/Lighting) 8 08-11-2012 11:23 PM
Amber Turn signals to yellow? deedz Cosmetic Modification (Interior/Exterior/Lighting) 1 08-01-2012 02:44 AM
