Drives: 2013 Ultramarine 86
Need help with LED turn signals.
So I got myself into a predicament. I bought some LED bulbs for the turn signals on my FRS. To avoid the hyper flashing, I also bought one of these:
http://www.v-leds.com/Vehicle-Specif...viewsTabAnchor However, I can't for the life of me figure out where does this thing go. Any help would be appreciated. Thanks! |
Sarcastic SOB
Sorry I dont know the actual location for the blinker relay but why not just activate the turn signal and listen for where the clicking sound is coming from?
Drives: 2013 Scion FR-S Firestorm Red MT
It goes to your fuse box. The manual has the fuses/relays diagramed and there should be one for turn signals.
I don't see anything in the manual about a flasher relay. I see a hazard light fuse but thats not the same size and probably not the one I'm looking for.
Nvm, I talked to V-LEDs and they told me the relay was under the steering wheel. PROBLEM SOLVED. Thanks for the help guys.
Drives: White Lancer Evolution X
Can you put up pics? I'm thinking of these LED's which claim to be plug and play but I'll believe it when I see it.
[ame="http://www.amazon.com/Scion-turning-signals-Bright-lights/dp/B008EWQDF2"]Amazon.com: 2013 Scion FR-S FRS 3157 Led turning signals 6060 SMD Bright led lights: Automotive[/ame] |
From what I understand about modern LEDs, they are all plug and play. It's just that using LEDs in place of turn signals cause hyper-flashing. I'll take a picture of where the relay is when I finish stitching up my e brake boot and walk downstairs to put it back on my car.
These are the best photos I could take right now. The relay is stuck to the bottom right underneath the steering wheel. It was such a PITA to remove the old relay though.Took me an hour and even then I ended up breaking the old one just to take it off. Also, a picture of my e brake... You get what you pay for (in my case $10)?
Drives: 1995 Ford Probe
switchbacks?
| Converting side marker to turn signals | ayau | Cosmetic Modification (Interior/Exterior/Lighting) | 33 | 07-13-2026 10:18 PM |
| Amber Turn signals to yellow? | deedz | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 08-01-2012 02:44 AM |
| Hand signals | Fugazi | BRZ First-Gen (2012+) — General Topics | 7 | 07-27-2012 11:13 PM |
| Simple One: Clear Turn Signals | Spaceywilly | Cosmetic Modification (Interior/Exterior/Lighting) | 37 | 07-26-2012 02:03 AM |
