Old 05-11-2013, 10:50 PM   #1
Juurian
Juurian's Avatar
Drives: 2013 Scion FRS WhiteOut
Need advice on some LE37's
So i have an opportunity to pick up some volks LE37's at a pretty good price with rubber.
Wheel Specs are:
5x100 (given) , 17x7.5 + 48 offset
I have checked the wheel directory for something similar but there weren't too many pictures. so i was wondering if anyones running something similar? was too worried if if the wheel would be sucked in too much or if it would be a decent fitment. please note i have HSD coil overs sitting in my closet waiting to be installed i'm looking to go only half an inch lower from stock so about 2 finger gaps.
these are the pictures that i was looking at, i have also purchased 5mm spacers to pretty much gauge how much i need to sit more flush.
http://www.ft86club.com/forums/showthread.php?t=16193
thanks in advance for your help
Winnipeg, Manitoba
Juurian is offline   Reply With Quote
Old 05-12-2013, 10:12 AM   #2
jshadeck
jshadeck's Avatar
Drives: 2013 Scion FR-S Whiteout 6MT
Offset is same as stock, width is .75" wider, so look at ur stock wheels and add .37" to both the inside and outside, thats where the volks will sit, then u can measure for spacers from that point (or measure for spacers off the stock wheels, and subtract .37" from ur desired spacer for the stock wheels)
jshadeck is offline   Reply With Quote
The Following User Says Thank You to jshadeck For This Useful Post:
Juurian (05-12-2013)
Old 05-12-2013, 12:01 PM   #3
Juurian
Juurian's Avatar
awesome! that gives me a good idea then
so i'm thinking i'm gonna need at least a 20mm hub spacer, how bad are these on the bearings? i'm guessing pretty bad lol..
and if anyone has any photos of the same set up please do share!
Winnipeg, Manitoba
Old 05-12-2013, 12:04 PM   #4
jshadeck
jshadeck's Avatar
Maybe someone else can chime in, im not sure what difference if any there is between a 48 offset wheel w good bolt on 20mm spacers vs a 28 offset rim..
Old 05-12-2013, 12:48 PM   #5
Juurian
Juurian's Avatar
i would assume it would put more load on the stock stud would be my guess.
Winnipeg, Manitoba
Old 05-12-2013, 12:54 PM   #6
mit_peid
Boosted Noob
mit_peid's Avatar
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
I'm in the same predicament with Volk SE37K 18x7.5 +48 wheels. From what I read about spacers on this forum and others, spacers aren't necessarily more unsafe than low offset wheels except for the possibility/risk of the additional nuts being mis-torqued and maybe coming loose if you screw up putting them on. Just need to check them initially and periodically. An additional risk is if spacers are used without new studs not allowing for sufficient turns (i believe you need at least 5-7 full turns of the nuts before tightening). The added weight of spacers are on the hub on the center so NBD compared to weight added to the edge of the wheel. For me I've settled on 15mm for front and 25mm for rear. These with the 7.5" wide wheels and +48 offset will get us within ~5mm (suck) of perfect flush with a 1" drop. I do want a flush look, but I don't really want to poke and start to mess with the car's excellent aerodynamics too much. I've decided to go for Ichiba V2 spacers even though I've heard H&R are higher quality. I also considered going for some no-brand spacers on eBay for 1/2 the costs of the Ichibas, but decided not to do that. The eBay ones should work since they are hub centric and made for Subarus 5x100 56.1mm hub, but I didn't want to take the risk. I hope this info helps.
mit_peid is offline   Reply With Quote
Old 05-12-2013, 05:19 PM   #7
dori.
Señor Member
dori.'s Avatar
Drives: white BRZ 6MT
you mean 0.5" wider/ 0.25" to both sides right?
unless I'm mistaken.
dori. is offline   Reply With Quote
Old 05-12-2013, 10:08 PM   #8
jshadeck
jshadeck's Avatar
Yes. No idea where my mind was at 10am today lol...
Edi: just looked, i was helping someone on the "will this fit" thread last night with 8.75" i musta had it stuck in my head for some reason... Whoops
Old 05-12-2013, 10:18 PM   #9
Juurian
Juurian's Avatar
i was actually planning on going with a 20mm hub spacer so it'll bacially bolt to my existing hub and will have new studs for the rim to mount on.
the 5mm spacer was just going to be used for gauging how much further i could go.
Winnipeg, Manitoba
Old 05-12-2013, 11:03 PM   #10
jshadeck
jshadeck's Avatar
Right, i think thats what he meant by "additional nuts"... Ha, that sounds bad out of context. From now on instead of "sausage party" im gonna call them "additional nut parties" haha
Old 05-13-2013, 03:24 AM   #11
Juurian
Juurian's Avatar
hmm i'll try 5m at the front then 20mm at the rear. gonna do maybe a 1 inch drop after all
Winnipeg, Manitoba
Old 05-13-2013, 08:18 AM   #12
jshadeck
jshadeck's Avatar
Just fyi, im 99% sure a 5mm spacer will not be available to you in a bolt on, but simply a slip on spacer, though 5mm should be fine, thats what i bought in case my fronts ever rub, but i have not had to put them on.
Old 05-13-2013, 11:51 AM   #13
Juurian
Juurian's Avatar
sorry for the misunderstanding , thats what i meant 5mm spacer at front and a 20mm bolt on hub spacer at the rear. i'll have the rims probably this Wednesday an i'll post pictures up.
Winnipeg, Manitoba
Old 05-13-2013, 11:55 AM   #14
jshadeck
jshadeck's Avatar
Np, i just know ive read people state that "5mm doesnt leave enough threads" which i dont really agree with personally, i think 5mm is prob the max i would run without longer studs (for 10mm if a bolt on 10mm wasnt possible)
Just be prepared for people to "hate on" ur setup a little as spacing the rears out will probably "ruin your scrub radius" or "destroy the cars ability to handle" or whatever else... I dont recall you asking about this fitment for track duty, so i didnt mention anything along those lines
Advise Needed Wheels USMC -FRS Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 02-03-2013 09:39 PM
Guys I can really use some advise... ScionFrsFan Engine, Exhaust, Transmission 27 12-31-2012 11:03 AM
Advise On Purchasing Fr-s Please! 7EASTAP Scion FR-S / Toyota 86 GT86 General Forum 7 09-18-2012 05:45 PM
Legal guru I need an advise Vino Scion FR-S / Toyota 86 GT86 General Forum 31 09-13-2012 06:13 AM
FR-S buying experience... advise chessplaya2010 Scion FR-S / Toyota 86 GT86 General Forum 30 07-31-2012 03:37 PM
