Stock Break Wear
I took my frs to get its 15k service and noticed on the form that my rear breaks measured 7mm and my fronts measured 9mm. I thought that cars were supposed to wear the fronts faster?
Thoughts? |
Drives: '13 DGM BRZ Limited
Cars with VSC use the rear brakes more to keep the car stable. Same thing happens with my wife's Mazda3.
| The Following User Says Thank You to cnk For This Useful Post: | strat61caster (04-24-2013) |
Drives: 13 DGM BRZ Ltd
What were the original values?
Much title. Wow.
Drives: 2013 BRZ Sport-Tech
most likely 12mm
hmmm..
Amateur Drifter
Drives: '13 FRS
Would the E-brake have anything to do with the wear on the rear brakes? Or is the ebrake a drum brake?
The Fail Boat
Drives: CWP S.B.
Just showing nannies at work when u don't know.
Ebrake is inside the hat on the rear rotor i believe.
#11 |
Drives: old
Most rear brake pads start out thinner than the front pads, I wouldn't worry about it.
#12 |
| Let's Discuss Tire Wear | SkitterSkotter | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 12 | 01-14-2014 11:35 PM |
| How much camber wear from Eibach Pro Kit | slowbrz | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 14 | 03-23-2013 07:25 PM |
| question about tire wear | driver01 | Tracking / Autocross / HPDE / Drifting | 8 | 08-05-2012 09:50 PM |
| Clutch wear? | Pakjk89 | Engine, Exhaust, Transmission | 102 | 04-12-2012 07:21 PM |
| wear your seatbelt... | bofa | Off-Topic Lounge [WARNING: NO POLITICS] | 17 | 07-16-2011 04:25 AM |
