Old 04-17-2013, 04:08 PM   #1
FR-Slide
Drives: 13 Whiteout 6MT
LED DRLs and Switchbacks question
Just picked up my 86 last weekend, and already can't leave it alone. First thing I need to address are the lights!
Tried to search a bit before starting from scratch, mostly in the DIY sections, so apologies if this is a n00b question, but...
I want to swap in LED DRLs over the normal halogens. Since the normal halogens just run at 1/2 power in DRL mode, do I need to adjust anything to make the LEDs run properly, such as removal of any fuses or resistors? Or do they just shine at 1 brightness for DRL and high-beam modes? Will running the DRLs greatly decrease their life expectancy, as in, should I disable DRL mode entirely when swapping?
Additionally, I also want to swap my markers for LED switchbacks (since I'd like to lose the amber, and would like some pseudo-fog lights). Just so I am clear, if I have on parking and/or headlights, these will remain on (and clear). If no parking/headlights are on (aka DRL mode), these will not be on. Correct? And all I will need for install of these is a flasher module to cure hyperflash?
Eventually I'll be doing HID swap too and will surely have more questions, but wanted to make sure I knew what I was getting into with "Phase 1" of my light upgrades. Thanks!
FR-Slide is offline   Reply With Quote
Testing Waters - Ful LED changeover $105($109 With Switchbacks for FRS) eljefe Interior Parts (Incl. Lighting) 11 08-09-2013 02:23 AM
LED DRLs on A/T?? eddieEndo Cosmetic Modification (Interior/Exterior/Lighting) 16 03-21-2013 06:47 AM
Does 6k HID's Go well With the Turn Signal Switchbacks J-Money Cosmetic Modification (Interior/Exterior/Lighting) 17 01-29-2013 10:41 PM
Difference Between $3 DRLS and $40 DRLS? FR-S Matt Cosmetic Modification (Interior/Exterior/Lighting) 14 12-31-2012 05:05 AM
