Old 02-24-2013, 07:09 PM   #1
ML
ML's Avatar
Drives: 13 White MT FR-S
Whiteline Camber bolts question (KCA416)
I have a set of Whiteline Camber bolts (KCA416), and I was wondering if they will replace the bottom strut bolt as well as the top? I tried to install them in the bottom and they seemed to be larger, they would not go in on the bottom mount. I was out of time, so I didn't get to check to see if they would go in the top mount. Has anyone else experienced this?
Old 02-24-2013, 07:15 PM   #2
Calum
That Guy
Drives: 2013 asphalt FRS MT
from what I remember, the top bolt is a 16mm, the bottom is a 14mm. Your KCA416 are 16mm so they should only fit the top holes.
The Following User Says Thank You to Calum For This Useful Post:
ML (02-24-2013)
Old 02-24-2013, 07:20 PM   #3
ML
ML's Avatar
I thought I had read that somewhere, but could not remember , THANKS!
Old 02-24-2013, 08:19 PM   #4
Calum
That Guy
:happy0180:
Old 02-24-2013, 10:41 PM   #5
whataboutbob
AutoX-10/10ths every run
Mine are mounted in the top holes.
Build thread:Here
Old 02-28-2013, 01:07 AM   #6
mtsui
Drives: 135i
how much more camber can the bolt get you? thanks
mtsui is offline   Reply With Quote
Old 03-08-2013, 12:15 AM   #7
Not4off
Not4off's Avatar
Drives: White Premium Manual
Subaru Camber Bolts
I installed camber bolts, then had car aligned. Max camber that I could get was -1.0
Not great, but better than stock.
2013 BRZ Premium Manual
2009 Porsche Carrera S Manual
Not4off is offline   Reply With Quote
Old 04-01-2013, 11:13 AM   #8
Red Barchetta
Drives: DGM BRZ
Did anyone with the whiteline bolt KCA416 have a hard time trying to tighten the nut? I could not get the nut to tighten down far enough. I tried the other nut and the same issue. Thanks.
Red Barchetta is offline   Reply With Quote
Old 04-01-2013, 11:30 AM   #9
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
use impact, they are indeed tight threaded
Huehuecoyotl is offline   Reply With Quote
The Following User Says Thank You to Huehuecoyotl For This Useful Post:
Red Barchetta (04-01-2013)
Old 04-01-2013, 11:38 AM   #10
Red Barchetta
Drives: DGM BRZ
Thank you. I will try it again this weekend.
Old 04-01-2013, 08:15 PM   #11
Huehuecoyotl
make sure you hold the bolt with a wrench so you dont loose your settings, Always good to get a proper alignement to make it all set right
Old 04-02-2013, 02:18 AM   #12
whataboutbob
I ended up with -1 3/8 on both sides in the front, but with RaceCompEngineering springs on the factory struts.
Build thread:Here
Old 04-02-2013, 11:25 AM   #13
Red Barchetta
Drives: DGM BRZ
I had the bolt pointed with the tab towards the strut with a wrench. However I did not have a deep socket for the nut and was trying to get it with a crescent wrench but having a tough go at it. Was afraid of cross threading and put the old camber bolt on since its my daily driver. Broke down today and ordered a cordless impact wrench. Thanks for help.
DIY | Video Installing Camber Crash Bolts Dezoris DIY (Do-It-Yourself) Guides 24 09-06-2016 11:07 AM
Where to buy Whiteline Camber Bolts whitefrs Suspension | Chassis | Brakes -- Sponsored by 949 Racing 28 07-26-2013 02:05 PM
Adjustable Camber Arms vs. Whiteline Camber Bushings digital_assassin Suspension | Chassis | Brakes -- Sponsored by 949 Racing 70 06-02-2013 06:06 AM
replace front crash bolts to add camber? Matt Andrews Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 06-15-2012 10:05 AM
