Old 03-19-2013, 12:09 PM   #1
MattM232
MattM232's Avatar
Drives: 2013 Scion FR-S Firestorm AT
Door Speaker Vibration
When I purchased my FR-S I went for the upgraded Pioneer audio system, but have not made any other modifications to the car. Whenever I listen to music with any bass frequency above about 20 volume, the passenger and driver door speakers vibrate the door panel so much that the bass frequency is inaudible.
Has anyone else experienced this issue? And since it is a Toyota installed stereo, would this be covered under warranty?
MattM232 is offline   Reply With Quote
Old 03-19-2013, 03:30 PM   #2
xjohnx
Grip>Slip
xjohnx's Avatar
$20 says it's your window switches. Put pressure with your finger on the plastic part of the window switch (right between the window buttons and mirror controls) and see if it stops.
Old 03-19-2013, 03:54 PM   #3
was385
Drives: MT WRB BRZ Limited, 2007 911s
My car does the same thing. I'm going to have them try and fix it next time I go in.
was385 is offline   Reply With Quote
Old 03-19-2013, 03:55 PM   #4
5hairpins
5hairpins's Avatar
Drives: 2013 MT Asphalt FR-S
Mine rattles pretty good after 40, occasionally on loud songs around 35. Not at 20. I usually switch from Feel to Hear to get the vibration to go away.
5hairpins is offline   Reply With Quote
Old 03-19-2013, 04:02 PM   #5
infinite012
Drives: 13 DGM BRZ Ltd
+1 to matting the switches, but also...
Take off the door panel and remove the weird white plastic rattle boxes inside your metal door skin. I have no idea why Subaru (I'm assuming Subaru because a similar white plastic rattle box was present in my 2008 STI) puts these in the doors, but they are annoying and useless.
Not my picture, but it shows the white plastic rattle box below the yellow plug:
infinite012 is offline   Reply With Quote
Old 03-19-2013, 04:07 PM   #6
mechaghost
mechaghost's Avatar
Drives: Silver AT Limited
What is the said function of that rattle box?
mechaghost is offline   Reply With Quote
Old 03-19-2013, 04:09 PM   #7
infinite012
To rattle and annoy.
Did you know that it's white?
Old 03-19-2013, 04:14 PM   #8
MattM232
MattM232's Avatar
Sorry I should've been more specific, it is lower on the door. I will definitely try this though!
This is the area where the noise seems to be coming from so I will definitely check it out. Thanks!
Old 03-19-2013, 04:20 PM   #9
strat61caster
strat61caster's Avatar
The white plastic looks like a ventilation flap so mold doesn't grow in your door and moisture doesn't seep into the cabin. Removing it would probably allow the latter to happen.
ineedyourdiddly
Old 03-19-2013, 04:23 PM   #10
infinite012
The moisture barrier (plastic bag that's "glued" on with the black goopy stuff) does that. I'm inclined to believe that the plastic thing is there for added "structure," however useful that plastic piece can be.
Old 03-19-2013, 04:26 PM   #11
strat61caster
Good call, I got turned around.
Moisture still gets trapped in that bag from experience, I still think it's some sort of ventilation.
ineedyourdiddly
Old 03-19-2013, 04:54 PM   #12
OrbitalEllipses
Drives: Attitude
Roll the window down after it rains...clearly moisture is getting trapped in the door frame.
Old 03-19-2013, 05:18 PM   #13
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
These are air bags sensors ! Don't be an idiot and remove or reposition them.
BAD ADVICE
Rayme is offline   Reply With Quote
Old 03-19-2013, 05:58 PM   #14
xjohnx
Grip>Slip
xjohnx's Avatar
BAD ADVICE
Might want to reread his post. he's talking about the white plastic flap beneath the sensor.
Rattle-ly Speaker Door Panels engee Cosmetic Modification (Interior/Exterior/Lighting) 45 11-25-2014 07:45 AM
Door Speaker Trim Rings Now Available zetaproducts.net Interior Parts (Incl. Lighting) 35 08-27-2013 09:52 AM
FRS door speaker vibration? hislargeness Electronics | Audio | NAV | Infotainment 12 08-19-2013 05:22 PM
Speaker Vibration JayNutter Electronics | Audio | NAV | Infotainment 12 07-31-2013 12:24 AM
Rattle in door speaker panels Lefty Electronics | Audio | NAV | Infotainment 2 06-18-2012 06:41 PM
