Old 06-24-2012, 02:09 PM   #1
engee
Drives: Subaru
Rattle-ly Speaker Door Panels
I know that some other members have experienced this as well and based on some other posts it appears that in order to reach the speaker panel, you need to remove the door card. My only question is whether there are any bolts that need to be removed prior to removing the door card or are they all clips?
Any info would be greatly appreciated and I will probably be fixing this problem next week.
engee is offline   Reply With Quote
Old 06-24-2012, 03:31 PM   #2
Lefty
Drives: Scion FR-S
Second this ^^
Took car to dealership and they did nothing about it. Just need to know how to take door panel off myself to insulate the area between speaker and grill.
Lefty is offline   Reply With Quote
Old 06-25-2012, 01:08 PM   #3
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
The rattle is coming from the passenger window control button, turn the bass up, hear the rattle, place your finger on the window button, insulate that area and it goes away, uses very little dynamat
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
Old 06-25-2012, 01:46 PM   #4
engee
Drives: Subaru
I swear the rattle is coming from the speaker panels.
The reason: Turned the bass up. Put my finger on the speaker panel that I think was rattling, and it went away. In order to reach the speaker panel though, it appears that you need to take off the whole door card.
Old 06-25-2012, 03:02 PM   #5
Lefty
Drives: Scion FR-S
Yeah, it is definitely coming from speaker panel.
Old 06-25-2012, 05:56 PM   #6
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
I've got the rattle on both door panels, but haven't really investigated it. Ill check tonight if it is the window switch or speaker panel.
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 06-26-2012, 12:32 PM   #7
carbonBLUE
Reverse Burnouts
well when you put your hand on it it absorbs the vibrations for the whole door i know its not my panels and just the window up/down switch
(wont forget you)
2011 Infiniti G37x
Old 06-26-2012, 12:38 PM   #8
FRSPirate
FRSPirate's Avatar
Drives: 13 Scion FRS Raven M/T, 05 Raven R6
Well, i was thinking fwk blown already as well until i read this thread and put my finger on the window switch panel. Def the window switch panel on my car too.
-Alex
05 Raven R6
13 Raven FRS M/T
FRSPirate is offline   Reply With Quote
Old 06-26-2012, 05:51 PM   #9
Lefty
Drives: Scion FR-S
carbonBLUE is right. After further investigation, the rattle is coming from the window switch panel. If you press down on it right next to the mirror adjustment knob the noise stops.
So, next question. How do I get the door panel off so I can dynomat it? I am newbie so anyone who wants to post some DIY pics would be much appreciated!
Old 06-26-2012, 06:32 PM   #10
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
Yea it's pretty annoying little switch ain't it.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 06-26-2012, 11:34 PM   #11
carbonBLUE
Reverse Burnouts
ummm also anyone else having a problem with the auto up/down on the passenger side window?
(wont forget you)
2011 Infiniti G37x
Old 06-27-2012, 12:01 AM   #12
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
My rattle is definitely from the window switches.
Sometimes the auto portion doesnt respond. Ill press the driver and passenger side buttons at the same time until both click, but only the driver side will go all the way down while the pass side stops. That doesnt happen all the time, but I wonder if the auto up/down learn procedure needs to be done on that window.
Parting out HERE
Old 06-27-2012, 12:14 AM   #13
carbonBLUE
Reverse Burnouts
yeah thats what im talking about, probably will be a recall to get it fixed
(wont forget you)
2011 Infiniti G37x
Old 06-27-2012, 11:21 AM   #14
Lefty
Drives: Scion FR-S
do you void car warranty if you dynamat a car?
Speaker Sizes Thefuzz Electronics | Audio | NAV | Infotainment 68 05-28-2021 06:18 PM
Undercarriage aero panels: Not on US BRZ? YankBoffin BRZ First-Gen (2012+) — General Topics 122 01-03-2015 10:56 PM
Rattle in door speaker panels Lefty Electronics | Audio | NAV | Infotainment 2 06-18-2012 06:41 PM
A/C Rattle? djliquidsteele Scion FR-S / Toyota 86 GT86 General Forum 2 06-17-2012 07:46 PM
Driver Side Speaker Housing Rattle Lefty Scion FR-S / Toyota 86 GT86 General Forum 2 06-12-2012 10:32 AM
