Old 02-26-2013, 07:11 AM   #1
brillo
Drives: 2013 Firestorm FR-S
DIY bushing replacement method
I've done some internet searches but I'm not finding a easy DIY method to press out control arm bushings with out a press.
How are folks tackling this from a shade tree perspective?
2013 Firestorm FR-S, MTX, build date 1/13.
brillo is offline   Reply With Quote
Old 02-26-2013, 12:35 PM   #2
Turn in Concepts
Turn in Concepts's Avatar
Take the control arms down to a shop that has a press and pay them to do the swap.
Turn in Concepts is offline   Reply With Quote
Old 02-26-2013, 03:51 PM   #3
Calum
That Guy
Drives: 2013 asphalt FRS MT
It depends on the bushings, but I normally use my bench vise.
Old 02-26-2013, 04:07 PM   #4
was385
Drives: MT WRB BRZ Limited, 2007 911s
Does autozone have a tool loan program for times like this? Never used it myself.
was385 is offline   Reply With Quote
Old 02-26-2013, 04:17 PM   #5
d1ck
Drives: Black 2013 FRS
If you don't care about the existing bushings do the following:
1. Get a torch and burn the bushings until you can pull out the centre collar by pulling and twisting with a good pair of vice grips.
2. Get a hack saw and assemble it with the blade through the hole left in the rubber
3. Make two cuts through the rubber and the metal sleeve of the bushing. The cuts should be close together almost like you're cutting a pie or something.
4. Use a flat top screwdriver to pry out the section you cut, and then the remaining larger piece.
I recommend doing this in a well ventilated area as the rubber burning is quite stinky. Also be careful when cutting through the outer metal sleeve with the hack saw. You want to avoid cutting into the sleeve which holds the bushing.
I successfully used this method to remove all 26 bushings in my Integra when I put in the Energy Suspension kit.
d1ck is offline   Reply With Quote
Old 02-27-2013, 12:45 AM   #6
FrX
Drives: 2013 Scion FR-S, 1993 Lexus SC300
While playing with fire is fun, It is a hassle and I got sick of it. A cheap 12-Ton press from Harbor-Freight made it a much quicker and cleaner process.
FrX is offline   Reply With Quote
Old 02-27-2013, 07:12 AM   #7
d1ck
You're absolutely right, but sometimes you've got to work with what you've got.
Old 02-27-2013, 11:13 AM   #8
s2kdrew
Drives: 2013 hot lava FRS
use a press is the easiest, since no matter how you get it out, you will still need a press to get it in.
2013 FRS
2000 S2000
2004 RSX-S
2002 RSX
s2kdrew is offline   Reply With Quote
Old 03-01-2013, 01:54 AM   #9
mtsui
Drives: 135i
done all the bushing on my 240sx....the easiest and cheapest way is...fire...just burn them all off
mtsui is offline   Reply With Quote
The Following User Says Thank You to mtsui For This Useful Post:
sandman126 (03-01-2013)
Old 03-01-2013, 04:11 PM   #10
jeebus
Drives: 2015 Mustang GT (on order)
I did them with my vice and some 5lb weights to sandwich the bushing. This was on my brother's e36/8, not my car.
jeebus is offline   Reply With Quote
Manual driving method frosty86 Scion FR-S / Toyota 86 GT86 General Forum 123 01-14-2013 10:13 AM
Whiteline transmission bushing and Perrin shifter bushing review. Superhatch Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 12-09-2012 08:40 PM
Run in method Dyno charts Surok AUSTRALIA 0 10-07-2012 11:29 PM
Proper 2 bucket wash method CU2MIKE Southern California 45 09-27-2012 07:15 PM
daily driving and heel-toe method denverizzles Scion FR-S / Toyota 86 GT86 General Forum 13 08-21-2012 03:51 PM
