Old 12-09-2012, 12:10 PM   #1
Superhatch
AIM4APX
Superhatch's Avatar
Drives: 2013 WRB BRZ Limited
Whiteline transmission bushing and Perrin shifter bushing review.
I installed these on Nov 25th, so I've had a little bit of time to get a feel for the changes to the car since install.
Install: Very easy for both pieces because I was using a lift. The transmission mount would have been ok using stands but the shifter bushing required some force to remove and replace and being on your back might make it a struggle.
Transmission bushing review: This piece is fantastic. The feel of the car changes immediately after it is installed. Gone is any slop in the transmission especially from same gear power on/of/on situations that used to jerk/bounce the driveline assembly. Because of the position of the mount, and what it's attached to I do notice a tiny bit of vibration when the car is under power. The best way to explain this is that you feel more connected to the motor/trans so when you are revving you can slightly feel it in your seat. It really adds a tiny bit of rawness to the car that it didn't have before. At higher RPM this feeling is increased a bit more and those who haven't driven with poly mounts before might be a bit unnerved as the vibration increases from 5500-7000 RPM. I love it, others might find it too raw.
Shifter bushing review: Can't feel any change. There might be a small change, and maybe if I just installed it w/o the transmission bushing it would be noticeable, but until the car has 75K on it and the OEM bushing is worn, I don't see any point in changing this out.
"It's very difficult to present technology as an overtly positive sales device to people who want an emotional car" -Chris Harris
Superhatch is offline   Reply With Quote
Old 12-09-2012, 08:40 PM   #2
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
Nice Review!
-Mike Paisan
11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts.
Call directly as We carry almost every manufacturer now, so before you buy parts call us.
Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) | T-1 Certified Amsoil Direct Jobber |AIM: AZP Installs
"Race Tested, Enthusiast Approved!"
AZP Installs is offline   Reply With Quote
Perrin Rear Shifter Bushing Install F1point4 DIY (Do-It-Yourself) Guides 55 10-21-2021 02:39 PM
Installed the Whiteline transmission bushing(no pics sorry) gmookher Engine, Exhaust, Transmission 9 06-27-2013 02:30 AM
FS: Perrin Rear Shifter Bushing green_comet Australia Classifieds 2 11-07-2012 02:04 AM
