Old 02-16-2013, 11:41 PM   #1
photomike
Vancan
photomike's Avatar
Drives: 2013 scion frs firestorm
Brake switch adjustment ?
My brake lights do not seem to come on when I first push the brake pedal.
Any one know how to adjust the brake switch? There is no nut , just plastic
connectors
JDM goodness JDM goodness JDM goodness JDM good
photomike is offline   Reply With Quote
Old 02-18-2013, 01:58 PM   #2
swag
swag's Avatar
Drives: 2013 Ltd A/T BRZ
Also having the same problem, the first few centimeters of brake movement do absolutely nothing...
swag is offline   Reply With Quote
Old 02-18-2013, 01:59 PM   #3
WillBRZ
WillBRZ's Avatar
Drives: 2013 BRZ Limited 6MT GBS
same here. Im fine with it.
2014 infiniti Q50 Daily 1996 Mazda Miata Racecar
SOLD -> Galaxy Blue Silica Subaru BRZ Limited 6MT
SOLD -> 2003.5 Infiniti G35 Sedan Emerald Mist
WillBRZ is offline   Reply With Quote
Old 02-19-2013, 02:23 AM   #4
photomike
Vancan
photomike's Avatar
No brake
Could glue something to the brake pedal arm ...?
Old 02-19-2013, 08:18 AM   #5
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I've noticed it Ali but haven't looked to see if there's an adjustment yet.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 02-19-2013, 08:39 AM   #6
Shankenstein
Frosty Carrot
Shankenstein's Avatar
Drives: The Atomic Carrot
It exists!
As far as adjusting it, the manual just says "Adjust the Switch - Stop Light". It appears to have a nut welded into the L-shaped arm to its left.
You'll either screw in/out the whole assembly or pivot the arm using the nut above.
I like 5-10 mm of travel before the switch turns on... which is usually means that the switch is already contacting the plate, when you adjust it. There's a deadzone built into most switches.
If you think you're nerd enough, join in the discussions about Suspension and Aerodynamic modelling!
Wall of Fame - JDL Auto Design, Raceseng, Vishnu Tuning, Penske Shocks, Nameless, Perrin, RaceComp Engineering, Essex/AP Racing, Verus, RacerX
Wall of Shame - aFe Takeda, Wilwood, FA20Club
Shankenstein is offline   Reply With Quote
Old 02-20-2013, 01:49 AM   #7
photomike
Vancan
photomike's Avatar
No brake
Originally Posted by Shankenstein View Post
It exists!
Thanks for the info Shankenstein!
Gas Pedal Adjustment ML Cosmetic Modification (Interior/Exterior/Lighting) 32 05-01-2017 09:26 PM
KW V3 camber adjustment olorin Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 01-28-2013 04:46 PM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 10:20 PM
Anyone going to switch badges? DougieFresh Scion FR-S / Toyota 86 GT86 General Forum 60 09-28-2011 02:56 AM
