Old 02-13-2013, 12:05 AM   #1
sw20kosh
Drives: 2013 Black FR-S
Hawk Blue 9012 Race Pads
I have these sitting here ready to go in. Could I run these in the fronts without changing the rears? Would that be a really bad idea? This is for HPDE. I am very naive when it comes to brakes.
If not, what rear pads would you run. HP+?
Old 02-13-2013, 02:08 AM   #2
I would recommend you use DTC60/70 instead. Blue's are corrosive, and you're gonna get a very lovely etching on your wheels that you won't be able to get off. The DTC are superior in pretty much every way to the Blue.
Use the same compound front and rear.
We carry pads that are easy to clean up after if that's a concern.
Old 02-13-2013, 02:42 AM   #3
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Please please listen to Mike on this one. DTC's are far superior.
Maybe a DTC30 for the rear or even the HP+
PRO86 | STL | LuckyDog
Old 02-13-2013, 02:46 AM   #4
sw20kosh
Thanks for the advice! Didn't know they were corrosive!
Old 02-13-2013, 09:06 AM   #5
JRitt
JRitt's Avatar
Drives: 2012 BRZ Premium WRB 6MT
Mike is right. Hawk Blue is great for scrubbing pad material off of a disc. In my opinion, that's about it. They are old technology. The newer DTC compounds from Hawk are better in every practical manner.
Essex Parts Services- AP Racing / Ferodo / Spiegler / Versodeck
Jeff Ritter|Mgr.- High Performance Division
www.essexparts.com
JRitt is offline   Reply With Quote
Old 02-13-2013, 10:46 AM   #6
invisage
Drives: Thunder Silver 86 GTS
How about hawk hp+ on the fronts and hps on the back? Was thinking this along with some motul brake fluid and braided lines just for an initial upgrade until I go FI and then would consider BBK.
invisage is offline   Reply With Quote
Old 02-13-2013, 10:57 AM   #7
agray56
Drives: Venza, Mustang, Acura, F150
Thats the combo I run on my Mustang for Autocross and track time and it works well. It should work well on these cars seeing as though they are quite a bit lighter, but the HP+ in particular is quite dusty.
agray56 is offline   Reply With Quote
Old 02-13-2013, 11:24 AM   #8
It really depends on how quick you are. If the HP+ is the most aggressive pad you've ever used, it'll probably work great for you at this point. However, if you're experienced, I'd point you straight to the Hawk DTC series.
We have a lot of local guys that are running Carbotech XP8 or XP10 for mixed duty. It's technically race pad, but works just fine for street use. Properly bedded, noise is non-existent, and the only real downside is dust; all pads with good bite dust.
I run race pads on my car year-round.
Old 02-13-2013, 11:27 AM   #9
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Blue's are death to.. everything. I used to LOVE blues and ran them for years.
My white GS-R was also pinkish/rustish because of them.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 02-13-2013, 11:46 AM   #10
invisage
Did my first ever track day last week and going for another one tomorrow. So far tyres are my biggest issue as I am still on stock but I have yet to decide on knew wheels so don't want to for out for new tyres yet. But I started to use my brakes more into the day as I was advised and was then that I started to notice a bit of fade so paint me inexperienced
Old 02-13-2013, 12:15 PM   #11
The HP+ will be perfect then. I'd recommend you transition to a more aggressive pad after you finish off that first set. It'll take you a while to finish them unless you start fading them.
Old 02-13-2013, 02:10 PM   #12
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I agree with all the comments. The SpecE30 guys used to love the Blues, but they are very old now, and the DTCs are the way to go if you are looking for a full track pad. If you don't plan to swap out pads after your track weekend, then stick with the HP+s, but I would still advise you to make sure you clean your wheels after each track day as they can still ruin your wheels. I did all my HPDE weekends on HP+s before getting my racing license and changing to the DTCs.
Old 02-13-2013, 02:33 PM   #13
I've daily driven on DTCs before. No noise when properly bedded!
Old 02-13-2013, 08:26 PM   #14
rice_classic
The real problem is getting them out of bed! Suckers are clingy! It's always about "them".
DIY - Changing Your Brake Pads (Race Pads upgrade) PMok DIY (Do-It-Yourself) Guides 53 09-03-2021 05:17 PM
Hawk HPS Front Pads Sheldon Brakes, Suspension, Chassis 1 01-04-2013 03:54 PM
Hawk HP Plus front brake pads on the track mtsound Tracking / Autocross / HPDE / Drifting 30 11-15-2012 02:24 PM
Hawk ceramic brake pads yomchi1989 AUSTRALIA 5 09-26-2012 10:39 AM
