CANADA Canada
Old 02-04-2013, 12:47 PM   #1
BryceRocket
Senor Member
BryceRocket's Avatar
Drives: Asphalt FR-S
Great results with Cquartz instead of Opticoat
On Sunday I had Bryan at Concours Touch auto detailing (http://www.concourstouch.com/) do a new car prep and Cquartz finest application. I thought the car looked decent when I picked it up from the dealer, but it's on a whole new level now. Saved some money in polishing time by getting this done now, and hopefully keep the scratches to a minimum.
Amazing how much deeper the paint looks with the Cquartz applied. Went for the Cquartz over the OptiGuard because of the 2-year warranty, and also the product seemed to be a little harder to scratch and objectively better shine.
Here's a couple cellphone shots when I picked it up. Highly recommend Bryan, he really does a great job.
BryceRocket is offline   Reply With Quote
Old 02-04-2013, 12:57 PM   #2
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
the question is, has it been proven to last as long as opti-coat?
chenshuo is offline   Reply With Quote
Old 02-04-2013, 02:14 PM   #3
brianc
OCD
brianc's Avatar
I don't see how its a valid comparison. I'd like to see someone opticoat half their car and cquartz the other half and see which one lasts longer.
brianc is offline   Reply With Quote
Old 02-04-2013, 02:42 PM   #4
s2kdrew
Drives: 2013 hot lava FRS
he had cquartz finest, not the regular cquartz. and is not a product any detailer could get.
2013 FRS
2000 S2000
2004 RSX-S
2002 RSX
s2kdrew is offline   Reply With Quote
Old 02-04-2013, 02:45 PM   #5
TemeCal
Drives: 86
This guy did side-by-side comparisons (half cquartz, half opticoat). Documented and took pictures of the entire process:
Click Here
TemeCal is offline   Reply With Quote
Old 02-04-2013, 03:06 PM   #6
picus
Drives: FJ
I don't think which one lasts longer will really be the determining factor when people choose Finest or OC; Finest is only marketed as lasting three years max. OC is billed as permanent, and has been around for 5+ years and shows no signs of failing on most cars. The guys getting Finest are doing it because it has a warranty, is is subjectively shinier than OC, it's much slicker, and seems to clean up a little easier. OC is less expensive since it isn't authorized detailers only. So while they are both coatings technically compete with each other, I think they are different enough currently that most people will choose based on which one suits them best.
picus is offline   Reply With Quote
Old 02-04-2013, 03:28 PM   #7
BryceRocket
Senor Member
I definitely opted for the cquartz finest because I liked the finish better and seemed smoother. I never expected it to last more than a couple years, but we'll see how it holds up.
Just hadn't seen nearly as many cars with cquartz finest compared to opticoat, so I wanted to share a good experience. Bryan who did the car really likes the product and so far I agree.
Old 02-05-2013, 04:04 PM   #8
Tdotmale
Drives: Subbie
nope. it hasn't been on the market long enough compared to OC.
the durability of the product will certainly be a determining factor. when searching the products, came across a test that OC was tested with washes using only dawn soap and automatic car washes for several years and it held up. no such thing has been done for cquartz f.
OC also has a warranty and also has a authorized detailer list.
Tdotmale is offline   Reply With Quote
Old 02-05-2013, 04:18 PM   #9
picus
Drives: FJ
I think you may have missed my point. Of course living up to the stated durability is key. That said, Finest is sold as lasting two years, OC is sold as permanent. If durability is the only factor I don't think many will cross shop the two; OC would be the obvious choice. That is why I mentioned that they are different enough to cater to different peoples needs.
RE: authorized installers/warranty - yes, opti coat pro (which is replacing OG, and is warrantied) has an authorized installers list. Opti Coat with no warranty will still be commercially available. I brought that up only to mention that Finest will have a higher upcharge than non warrantied Opti Coat. Opti Coat pro will have the same upcharge as Finest in most cases.
Old 02-06-2013, 09:30 PM   #10
BryceRocket
Senor Member
Bryan had mentioned to me that the OC Pro warranty isn't available in Canada... No idea why.
Old 02-06-2013, 10:06 PM   #11
asia_minor
Superleggera
Drives: 2016 Mazda MX-5
OC was never about looks, just putting it out there. when I want the car to look it's best, i always top off with some wax, even though it will only stick to the OC for a few days.
asia_minor is offline   Reply With Quote
Old 02-07-2013, 04:14 PM   #12
picus
Drives: FJ
He's right. It's because right now the insurance company that covers the warranty will only cover the U.S. So until that changes the only warrantied coating is Finest. Currently I think there are only three guys authorized to install it in Canada, two in the GTA and one near Windsor. http://www.carpro-us.com/authorized-finest-installers/
Old 02-07-2013, 04:22 PM   #13
tuckdaddy
Because Racecar
tuckdaddy's Avatar
Drives: 2013 Asphalt FRS
The c-quartz will look much better than opticoat and require a slight bit less care while retaing a bright deep finish
had Jason my local Adams Polishes rep here in San Antonio show me on his truck half the hood is opticoat and the other c-quartz and after 8 months and many automatic paint killing washes later the cquartz was amoother and held a deaper shine than opticoat with less swirling/scrathces
both these products are essentially clear coat for your clear coat...Does not protect againt rockchips or any other shananigens like that.
If i were to ever put a "Nano-Sealent" on my car i would go with c-quartz much better product
tuckdaddy is offline   Reply With Quote
Old 02-07-2013, 11:47 PM   #14
Sport-Tech
Sport-Tech's Avatar
Drives: TBD
Car looks great...now lose the ugly dealer-advertising plate holders and you're good to go.
Sport-Tech is offline   Reply With Quote
Another Paint Protection Option: CQuartz Finest TLC Dave Cleaning and Detailing 4 03-23-2013 09:00 PM
Great Shark Fin pre painted factory color great price marinjim Cosmetic Modification (Interior/Exterior/Lighting) 42 12-03-2012 11:49 PM
Cquartz finest Applied-firestorm kendalldwhite Scion FR-S / Toyota 86 GT86 General Forum 21 09-25-2012 11:44 AM
Cquartz "semi permanent" protection /FR-S Esoteric Cosmetic Modification (Interior/Exterior/Lighting) 4 08-25-2012 10:16 AM
