Backyard Fabricator
Drives: JZX83, SF5 GT, ZZE82 turbo
Darton Sleeves for FA20
6/22/12-2/6/24
Call me stupid but what are those sleeves for?
Extending the chambers/oil flow/oil lubrication/etc.?
Backyard Fabricator
allows you to run bigger pistons/more boost etc and they also have a "closed deck" skirt at the top now to help prevent bore-shift.
Mainly for the really serious engine builds. |
Scrape Master
Drives: Goal: Oldest FRS State Side
Correct me if im wrong but our engines are unsleeved, so we would just need to bore and install these sleeves for stock pistons to fit?
Drives: GT86
Why would you go to all that trouble just to re-fit the OEM pistons?
#6 | |
Backyard Fabricator
stock bores have a metal matrix liner cast into them. Bore that out, press these in, deck the sleeves to match the block, bore and finish the sleeves to fit for your choice of pistons.
From the "FA20 Engine Mechanical - Engine Unit - Details (2013 FR-S)" doc from toyota: Quote:
6/22/12-2/6/24
Mmmmm so it slides Into the combustion chamber?
bigger pistons ... ? How so, the diameter is set constant only xy horizontal expansion is possible so it lengthens the chamber with this mod to the block .. does this really work? hahaha
Scrape Master
well i mean same size as stock.
Drives: 2013 hot lava FRS
this is mainly for people who are rebuilding the engine, with all high performance internal parts. stroker kits is what these sleeve for, since original block wont have enough strength once you increase the engine displacement. and could handle high boost power too.
2013 FRS
2000 S2000 2004 RSX-S 2002 RSX |
#10 |
Drives: 01 MR-s, 78 280z, 13 FR-s
That didnt take long.
#11 |
Drives: Firestorm red fr-s
#12 |
Drives: 2003 Subaru Outback
It addresses the issues of having an open deck block, not ideal for boost and big power.
#13 | |
6/22/12-2/6/24
So they slip into the cooling part of the block to add rigidity and keep its form under high rpm/pressures
#14 |
| STAGE 3 FA20 | cf6mech | Engine, Exhaust, Transmission | 44 | 08-09-2013 01:55 PM |
| FA20 Dimensions | Matador | Engine, Exhaust, Transmission | 9 | 07-31-2013 12:45 AM |
| FA20 Shortblock | Ishii Motors | Engine, Exhaust, Transmission | 16 | 08-04-2012 09:28 AM |
| question about cylinder walls(sleeves) | carbonBLUE | Engine, Exhaust, Transmission | 12 | 04-13-2012 06:21 PM |
| HKS s/c FA20?? | Rome | Scion FR-S / Toyota 86 GT86 General Forum | 6 | 04-04-2012 12:13 PM |
