Old 08-03-2012, 02:15 PM   #1
Ishii Motors
Ishii Motors's Avatar
Drives: Scion FRS
FA20 Shortblock
Got my engine today. This is most likely the first FA20 shortblock in the USA.
This engine will be fitted with prototype low compression pistons and high strength rods! I can't wait!!!
Thought everyone would enjoy a look at what powers our beloved cars.
Ishii
Ishii Motors is offline
Old 08-03-2012, 02:19 PM   #2
SkullWorks
Drives: SSM LT MT BRZ
very nice cant wait to see what will be had
SkullWorks is offline
Old 08-03-2012, 02:25 PM   #3
FT-86GOD
Senior Rocket Bunny
FT-86GOD's Avatar
Drives: 1982 XX KE70
Exciting!!!........
BOSOZOKU STYLE BITCH........
FT-86GOD is offline
Old 08-03-2012, 02:51 PM   #4
Visconti
Drives: 05 STi
What kind of $$ did the short block cost?
Visconti is offline
Old 08-03-2012, 02:58 PM   #5
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
Wowzers!
Silverdub is offline
Old 08-03-2012, 09:17 PM   #6
RallySport Direct
RallySport Direct's Avatar
Drives: 2014 Widebody Cosworth FR-S
Nice!! Will you be updating this thread with the build?
Thanks,
Rick
RallySport Direct is offline
Old 08-03-2012, 09:49 PM   #7
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
Pretty sweet. Block casting looks pretty smooth. The cylinders are lined, but approx how thick are the steel sleeves?
Coheed is offline
Old 08-03-2012, 10:02 PM   #8
20valvewynn83
20valvewynn83's Avatar
Drives: 2013 FRS/01 Tacoma
That's pretty impressive that they made all the main bearing boors the same. Number 2 bearing all across is good presison. Wonder what the rod bearing are . Looks nice and cant wait to see the end result.
20valvewynn83 is offline
Old 08-03-2012, 11:07 PM   #9
subatoy
subatoy's Avatar
Drives: subatoy
ignorant question...
what is the advantage of a short block?
subatoy is offline
Old 08-03-2012, 11:11 PM   #10
Opposed
Drives: 2013 Asphalt FR-S
Nothing. The short block is referred to as the engine block assembly with rods and pistons ect, without anything else. The heads are not included. The purpose in this case is to install stronger piston's and rods to use it under a possibly high boost application.
Opposed is offline
Old 08-03-2012, 11:18 PM   #11
ahausheer
Re-member
Drives: Toyota camry
I thought the FA had a semi closed deck?
Nothing decays like progress, and nothing preserves like neglect.
ahausheer is offline
Old 08-03-2012, 11:34 PM   #12
WolfsFang
Scrape Master
WolfsFang's Avatar
Drives: Goal: Oldest FRS State Side
no it has a open deck
You do realize comparing the BRZ to the FR-S is like comparing which hand you love masterbating too right?
WolfsFang is offline
Old 08-04-2012, 12:30 AM   #13
KAB-FRS
KAB-FRS's Avatar
Drives: 2013 Scion FRS/whiteout,MT
Can't wait to see this build.
KAB-FRS is offline
Old 08-04-2012, 09:07 AM   #14
Don@Accelerated
Don@Accelerated's Avatar
Ishii
I dunno if its the first !
-Don
Don@Accelerated is offline
Early proposal: FA20 with a FB25 shortblock, .5l more displacement anyone? Kostamojen Engine, Exhaust, Transmission 90 03-20-2022 06:05 PM
Which oil filter for the FA20? ft86Fan Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 58 07-09-2012 12:21 PM
FA20 Interference... phm14 Engine, Exhaust, Transmission 3 07-02-2012 06:18 PM
HKS s/c FA20?? Rome Scion FR-S / Toyota 86 GT86 General Forum 6 04-04-2012 12:13 PM
FA20 for sale coyote AUSTRALIA 1 12-01-2011 12:53 AM
