Old 01-05-2013, 06:39 PM   #1
pcporo
No Martians here?
pcporo's Avatar
Drives: FR-S Asphalt MT
speaker replacement
I'm looking to replace the speakers in my FR-S. Looking for suggestions for those of you who have done so already. Don't plan on adding a sub yet or replacing the basic head unit. I've been looking around quite a bit and haven't been able to find much other than the size needed. Thanks in advance. Thought we could use a thread of who has what installed and how they like it.
pcporo is offline   Reply With Quote
Old 01-22-2013, 06:51 PM   #2
Big Sexy
Drives: 2013 FRS
I'm in the same boat...
I'm deployed in Afghan, returning in less than a month, ordered me a FRS to be delivered about the time I'm getting home.... wanting to replace the factory speakers. I'm interested in suggestions as well....
Big Sexy is offline   Reply With Quote
Old 01-22-2013, 07:02 PM   #3
SMOKETREES
Lowered Lifestyle
SMOKETREES's Avatar
Drives: Scion Fr-S
Add a sub and a double din deck that has equalizer settings and can change x-over settings to make changes to the factory speakers. Just added 2 JL Wv2 10's and a pioneer deck and it sounds really crisp! I will be changing out factory speakers later on. I just wanted to get the base and most expensive portion out of the way. But if you dont want subs...... Look into Vocal or JL c5 or c3's.......
SMOKETREES is offline   Reply With Quote
Old 01-22-2013, 11:20 PM   #4
6-Shift
Señor Member
6-Shift's Avatar
Drives: 2013 Raven, Drifty things
I feel like there needs to be one end all be all video of someone replacing every speaker and adding a new head unit/subwoofer so that questions like this can be answered more easily. Audio is one of those things where everyone has a preference. Idk if there are any audio specialists on the forum though :/
T O U G E - C U L T U R E
Follow me on instagram! :@tougeculture_chris
'13 FR-S, SBD Turbo kit, Tein Flex Z coils, other stuff. Drifting and autocross.
6-Shift is offline   Reply With Quote
Old 01-22-2013, 11:25 PM   #5
Gir
Gir's Avatar
Drives: 86 GT Manual - Sonic Blue
I put Focal P165v15 splits in the front. 6.5" speakers fit in the door no problem, but you'll need to make a spacer (I just used 16mm MDF), as the standard bracket is part of the stock speaker. I used an aluminium bracket to mount the tweeter where the 3" dash hole is (it wouldn't fit in the tweeter area). For the rears, the stock speakers are 3", so I put in a pair of 2 way 4" Rockford Powers. Once again, you'll need to make an MDF spacer, but there's enough space in the back sides for up to an 8" sub (You'll need to modify though, the grill is only 3.5", and it's off to the side).
Gir is offline   Reply With Quote
Old 01-22-2013, 11:45 PM   #6
Mo707
Mo707's Avatar
arent the stock ones odd shaped?
Mo707 is offline   Reply With Quote
Old 01-23-2013, 02:02 AM   #7
cruzinbill
Drives: Argento 6spd FR-S
I would say just get a JBL MS8, it will do wonders and anything you may do down the road would shine even more.
cruzinbill is offline   Reply With Quote
front door 6" speaker replacement mount derka-derka Electronics | Audio | NAV | Infotainment 5 12-13-2012 11:23 AM
speaker replacement 20valvewynn83 Electronics | Audio | NAV | Infotainment 3 12-12-2012 02:36 AM
Speaker issues. Hotlava86 Issues | Warranty | Recalls / TSB 19 10-18-2012 03:06 PM
Speaker help! KRAZYK Electronics | Audio | NAV | Infotainment 0 08-02-2012 08:54 AM
Thoughts on ease of speaker replacement? ahausheer Scion FR-S / Toyota 86 GT86 General Forum 36 11-29-2011 11:16 AM
