Old 08-09-2012, 09:40 AM   #1
Hotlava86
Hotlava86's Avatar
Drives: 2013 Hot lava Fr-s, 2007 Mazda 3
Speaker issues.
So i have had my FR-S for about 2 months now. Within the first 48 of owning the car my passenger speaker blew out (or at least sounded like it had). I took it to the dealership a week or so later showed the tech the problem, he instantly said that yes the speaker was in fact blown and would be replaced under warranty. A week later the replacement speaker came in and they replaced it. Well now less than 2 days later the EXACT same speaker is blown out again.
I am talking about the door speaker on the passengers side.
EQ settings are moderate at best. Bass 2, treble 3, fade and balance set to Middle, ASR high rate, ASL medium, SSR feel, interface USB, mode FR-S.
So i am not BLASTING bass through them. The volume is typically around 25-30 on the highway and 20-25 in the city.
So today i will be discussing with the dealership about upgrading my base system to the premium system for free because of the hassel.
I feel as if the problem is in the Amp or the wiring. What do you guys think?
Hotlava86 is offline   Reply With Quote
Old 08-09-2012, 10:58 AM   #2
Xanatos
Xanatos's Avatar
Drives: @redline, '14 BRZ, '98 Forester
Its possible that its an amp issue but do you feel that its louder coming from that side? If not I dont see the amp being an issue and it would probably be just an isolated speaker problem.
I would recommend you break-in your speakers for at least 15-30 hours before turning up the volume. I dont have a FR-S so I dont know how loud the 25-30 setting is but if you dont properly breakin speakers they can be damaged.
Xanatos is offline   Reply With Quote
Old 08-09-2012, 12:14 PM   #3
rick
rick's Avatar
Drives: 86
Seriously ?! You gotta break-in car speakers?!?!
rick is offline   Reply With Quote
Old 08-09-2012, 12:36 PM   #4
Sideways?
Drives: Toyota GT86 - Blue - Leather - Nav
Sounds like it could be a short in the wiring and since it has been replaced once already it is likely the wiring at the car end as opposed to the speaker end...
Otherwise it could have chafed through somewhere on the route from head unit to speaker and that is causing the issue.
Or you have a loose terminal on the speaker / wire and it works its way nearly off once you have been driving around a bit...
Sideways? is offline   Reply With Quote
Old 08-10-2012, 10:38 AM   #5
Hotlava86
Hotlava86's Avatar
Today they are claiming that it is a door panel issue (the window switch) i kind of doubt that, and if it is then the techs are really dumb for not seeing it when they replaced what would have been a perfectly good speaker.
Raising the bar one step at a time!
Kansas City FR-S/BRZ Facebook group. https://www.facebook.com/groups/452909128083343/
Hotlava86's Build thread!http://www.ft86club.com/forums/showthread.php?t=14152
Old 08-10-2012, 11:01 AM   #6
Xanatos
Xanatos's Avatar
Yup! All speakers and headphones have a break-in period. They don't produce their true sound quality until their broken in.
How does the window switch have an effect on the speaker? Short circuit?
Old 08-10-2012, 11:07 AM   #7
Hotlava86
Hotlava86's Avatar
not enough insulation underneath it and it causes it to rattle. there isn't apparently a whole lot of insulation or sound dampening in the doors so now toyota corporate has been called in again as of 5 minutes ago. We will see if they decide to be decent and fix the issue.
Old 08-14-2012, 07:21 PM   #8
zxperez1
Guest
Posts: n/a
My passenger side speaker start to rattle the third day. I didn't go over 35 at any time. I think my issue is also the trim panel. It rattles and i don't hear any popping or cracking to make me think the speaker blew. I do plan to upgrade speakers but I would like the rattle fixed before i messing around and get blamed for the rattle.
Old 08-14-2012, 07:37 PM   #9
tintumz22
tintumz22's Avatar
Drives: 2013 Scion FR-S Toyota 86
Yup!! they have break in periods. I have lots of headphones and as per manual instructions it needs to be broken in.
tintumz22 is offline   Reply With Quote
Old 08-15-2012, 03:37 PM   #10
Hotlava86
Hotlava86's Avatar
well i ended up throwing a 12" Rockford sub in the trunk so no more bass up front anymore its all from the trunk now! NOW ON TO THE TRUNK RATTLES!
Old 08-15-2012, 05:03 PM   #11
tintumz22
tintumz22's Avatar
Let the tail be rattled!
Old 09-25-2012, 07:33 PM   #12
Arctek83
Arctek83's Avatar
Drives: FR-S Raven
At first I thought I had a blown speaker, but turned out it was my door panel rattling. See the following post of someone else who had the same issue.
http://www.fr-sforum.com/forums/fr-s...er-rattle.html
Arctek83 is offline   Reply With Quote
Old 09-25-2012, 07:40 PM   #13
DaJo
FT86Club Vancouver
DaJo's Avatar
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
I wish I knew how loud exactly you were playing your music...
20-30, that's super load in the BRZ Canadian spec Head-unit anyway...
I have it on 10 and that's already blasting my ears.
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT
2010-2012
2013 BRZ Sport-Tech 6AT
Since '12 (OEM+ STI tS Build)
2015 Lexus IS250 AWD F-Sport 2 2015-2018
2018 Lexus NX300 F-Sport 3 Since '18
DaJo is offline   Reply With Quote
Old 10-07-2012, 02:15 AM   #14
chrisbfrs
2012 car of the year
chrisbfrs's Avatar
Drives: Frontengine Reardrive-Sportcar
My driver side door speaker rattles like crazy. Gonna bring it to be serviced. I dont hear it from passenger side. Im not sure when it started but its been doing it for a while.
chrisbfrs is offline   Reply With Quote
Speaker Sizes Thefuzz Electronics | Audio | NAV | Infotainment 68 05-28-2021 06:18 PM
Rattle-ly Speaker Door Panels engee Cosmetic Modification (Interior/Exterior/Lighting) 45 11-25-2014 07:45 AM
Speaker help! KRAZYK Electronics | Audio | NAV | Infotainment 0 08-02-2012 08:54 AM
Popped up dashboard speaker grill Laika BRZ First-Gen (2012+) — General Topics 8 06-20-2012 11:35 PM
8 Speaker stereo specs? Rstalter77 BRZ First-Gen (2012+) — General Topics 56 04-24-2012 04:43 AM
