Old 12-30-2012, 05:42 PM   #1
FRSowner
Drives: Hot Lava A/T
TPMS warning light
FRSowner is offline   Reply With Quote
Old 12-30-2012, 06:00 PM   #2
russv
First 86
russv's Avatar
Drives: Scion FRS Argento Automatic
Reset tire pressure, then drive it for a bit. TPMS will go off. Common problem when temp drops.
Life is short...NO BORING CARS
russv is offline   Reply With Quote
Old 12-30-2012, 06:14 PM   #3
ziggz501
ziggz501's Avatar
Yup, its not that the cold is tripping up the sensor, but rather the cold is actually lowering the pressure in the tire. The TPMS only has just a few psi threshold before it goes off, so make sure its right around the amount of pressure that the tire asks for, and then drive it around to make it switch off.
ziggz501 is offline   Reply With Quote
Old 12-30-2012, 06:18 PM   #4
ziggz501
ziggz501's Avatar
Not sure. I haven't actually checked mine yet. Only had it for a month! It should say on the inside of your door what the stock tires recommended pressure is.
Old 12-30-2012, 06:22 PM   #5
hunter3232792
hunter3232792's Avatar
Drives: FRS
Originally Posted by FRSowner View Post
Yea, that's what I meant - the cold temps have lowered the tire pressures. What is the recommended psi for stock tires? The sidewalls have a limit of 51psi. I've always ran 30 - 35 psi.
it says it on the side of the door once you open it
hunter3232792 is offline   Reply With Quote
Old 12-30-2012, 06:24 PM   #6
shishand
Drives: Whiteout
35psi is the recommended pressure
shishand is offline   Reply With Quote
Old 12-30-2012, 08:24 PM   #7
matthewl
Drives: FR-S white 6 speed
If you have the US standard FR-S with Michelin Primacy HP summer tires, the door says 35 psi.
matthewl is offline   Reply With Quote
Issues - Traction control and ABS warning light on G86 Issues | Warranty | Recalls / TSB 109 10-17-2021 04:32 PM
Blocking Your TPMS Light DarrenDriven DIY (Do-It-Yourself) Guides 77 03-29-2017 11:18 PM
TPMS light michael317 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 50 08-05-2014 04:12 PM
Warning light came on, what could it be? whtchocla7e Issues | Warranty | Recalls / TSB 13 10-21-2012 04:20 PM
TPMS warning light **New Info** sdiver68 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 29 10-11-2012 07:25 PM
