Old 09-05-2012, 12:29 AM   #1
michael317
michael317's Avatar
Drives: BRZ Limited
TPMS light
TPMS light. you have aftermarket wheel and have the light and want to get rid of it. The tpms system on the brz is not the one subaru been using, the tires need to be rotating for the ecu to sense the frequency of the sensor. This is a toyota system, just sense pressure. Assuming you are not planing to use your donut at all. you can remove all your sensors and just tape or put it inside your donut tire. ( you will need to bring the donut and sensors a tire shop have them dismount the spare so you can just throw the sensor in it. or tape it.) have the spare inflate at 50psi. put the donut back into the spare tire compartment. TPMS light will never be on with your aftermarket wheels.
*use this tip under your own discretion*
michael317 is offline   Reply With Quote
Old 09-05-2012, 12:44 AM   #2
Phaedrus29
Phaedrus29's Avatar
Drives: 2013 Subaru BRZ
Originally Posted by michael317 View Post
...the tires need to be rotating for the ecu to sense the frequency of the sensor.
So how could throwing the sensors in the spare possibly work?
Phaedrus29 is offline   Reply With Quote
Old 09-05-2012, 01:28 AM   #3
michael317
michael317's Avatar
Drives: BRZ Limited
your spare will be inflated with the sensors inside the spare. sensor is pressurized and sense the tire is inflated within the range. spare is inside your car so the ecu pick up the sensor ids so your tpms light will not come on.
you can try this. put your aftermarket wheels on in your garage. have your stock set of tires with sensor in the garage. your tpms light will not come on. after a while of driving your light will flash and stay on but once you return to your garage and close enough for the ecu to pick up the tire sensor ids your tpms light then turn off. which is the same as throwing the sensors into your spare tire you wont be using it (if you do the sensor will rattle inside when rotating)
Old 09-05-2012, 01:34 AM   #4
Willsonk
Drives: Scion FR-S Asphalt AT & XB
TPMS sensors sends information to TPMS CPU. Does not need to be rotating sensors will keep sending signal. I would not put sensors into the spare. If you exceed the pressure ...... meaning over pressuring the sensors might set the warning light off. If your going to do it. Buy a small lawnmower rim and tire and put the sensors into it and set the right pressure.
Willsonk is offline   Reply With Quote
Old 09-05-2012, 02:01 AM   #5
Phaedrus29
Phaedrus29's Avatar
My point was that the spare isn't rotating, and as you say, the sensors need to be rotating to prevent the tpms light. Are you saying that the sensors rattling around in the spare is enough to keep the light off?
And if the sensors need to be rotating, how will having the stock set of tires sitting in the garage help?
Old 09-05-2012, 02:58 AM   #6
artizhay
artizhay's Avatar
Drives: Scion FR-S Firestorm MT
Send a message via AIM to artizhay Send a message via MSN to artizhay Send a message via Yahoo to artizhay
Actually, what I gathered from his first post is that the BRZ does not use the standard Subaru system that necessitates wheel rotation. Rather, it is a Toyota system that merely measures tire pressure. So bringing up the wheel rotation issue is completely besides the point since it doesn't apply to this car. You took a phrase out of the context of his original post, ignoring the other information around it.
artizhay is offline   Reply With Quote
Old 09-05-2012, 08:05 AM   #7
xjohnx
Grip>Slip
xjohnx's Avatar
They require rotation.
Old 09-05-2012, 08:16 AM   #8
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
Have you acutally tested this???
This would be great, but it goes against what is known about most of the latest generation of TPMS systems.
Old 09-05-2012, 08:44 AM   #9
HunterGreene
Hail Magnet
HunterGreene's Avatar
Just to weigh in, after I ran this through my "bad english filter":
Putting the Tire Pressure Monitoring System sensors inside your spare tire wouldn't work. Why? Because regardless of rotation (I don't know if its required or not, if the sensors are anything like the ones I have on my tC, which didn't require rotation) the sensors measure pressure as a differential against the atmosphere. In other words, in order to read pressure, there must be different pressures on either side of the sensor. Putting the whole thing inside of a pressurized donut will still end up reading zero.
Of course, if its a self-contained system, I would be totally wrong.
Last point, I believe it is possible to shut this light off in the system, as opposed to trying to find a work-around. Ask your dealer.
Old 09-05-2012, 10:20 AM   #10
michael317
michael317's Avatar
Drives: BRZ Limited
Like i said use it under your own discretion. I am saying this because i am a tech at a Lexus dealer. TMPS system on the BRZ is a toyota system. which DOES NOT require rotation. have i test it yes i have done it a few times for lexus customers with aftermarket wheels which they requested. I have also tested the with my own car where tpms light is on and if i am close enough to my stock set of wheel with the sensors the light goes off when parked. I will be doing this on my own car when i return to work next week.
ps: putting the sensors in the spare is just to fool the sensor that there are enough psi around it. if you are planning to use your spare then use willsonks advise in the previous post that will work as well
Old 09-05-2012, 10:37 AM   #11
artizhay
artizhay's Avatar
Nope.
Old 09-05-2012, 11:32 AM   #12
neutron256
neutron256's Avatar
I see a lot of people saying they don't need rotation.
Can anyone say they have actually tested this?
No offense but until someone can say they have tried it and it worked I'm doubtful.
Old 09-05-2012, 11:35 AM   #13
xjohnx
Grip>Slip
xjohnx's Avatar
Nope.
Source? This has been covered multiple times in the past on this board. It's the same reason that TPMS pipe bomb will not work with our cars.
Old 09-06-2012, 02:52 AM   #14
jdmitr
jdmitr's Avatar
Drives: BRZ Limited - '85 Corolla GTS coupe
I have Rays gram light 57xtreme wheels on mine and no tpms light with over 1500 miles. The sensors are still in my oem wheels. I would assume that this may be a "track" feature that when it does not see any response it may go into a type of "track mode".
2013 Subaru BRZ - Satin White Pearl 6mt - HKS v3 GT Supercharger running 93 octane at 270whp -
1985 Toyota Corolla GTS coupe - F20c swapped
BK Industries
jdmitr is offline   Reply With Quote
ZILLA: (How-To) *REAR FOG LIGHT WITH BRAKE LIGHT* MOD! ZILLA DIY (Do-It-Yourself) Guides 117 09-19-2017 10:17 AM
Blocking Your TPMS Light DarrenDriven DIY (Do-It-Yourself) Guides 77 03-29-2017 11:18 PM
Update on TPMS - No light without sensors! trueno86power Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 15 05-11-2014 03:45 AM
TPMS warning light **New Info** sdiver68 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 29 10-11-2012 07:25 PM
Risk Racing Light Mine Professional Magneti - Magnetic mini light fixture! DjDATZ Off-Topic Lounge [WARNING: NO POLITICS] 0 06-28-2012 11:21 AM
