Old 10-12-2012, 08:27 AM   #1
whtchocla7e
Drives: 2013 FR-S Hot Lava
Warning light came on, what could it be?
Hi guys,
The yellow warning with an exclamation sign on the speedmeter side, right below the high-beam indicator. Any idea what it means?
I went to start my car this morning and this light stayed on... Didn't know what it was so I rode the bike in to work on this cold ass morning..
Damn it...
Live to drive another day
whtchocla7e is offline   Reply With Quote
Old 10-12-2012, 08:31 AM   #2
atledreier
Drives: GT86 DGM
TPMS light?
atledreier is offline   Reply With Quote
Old 10-12-2012, 08:34 AM   #3
Eurasianman
Chief
Eurasianman's Avatar
Drives: 2013 DGM BRZ Premium 6MT
It means low tire pressure.
Side note: Nice Christmas lights, a bit early though, isn't it?
Eurasianman is offline   Reply With Quote
Old 10-12-2012, 09:04 AM   #4
cnk
Drives: '13 DGM BRZ Limited
It's the TPMS as stated above. You should really read your owner's manual as there's a lot of information in there including what all the indicator lights are.
cnk is offline   Reply With Quote
Old 10-12-2012, 09:19 AM   #5
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
QFT.
This is a 30 000$ machine, take care of it and learn how it works.
Also since you didn't read the manual and seems to not know what the warning lights mean, if the oil light ever comes on, DON'T DRIVE IT! STOP THE ENGINE!!! A lot of people don't even know that and kill their motors driving to the dealer/garage …And that's clearly written in any manual to not drive the car with that light on.
Have a good day
Rayme is offline   Reply With Quote
Old 10-12-2012, 10:51 AM   #6
whtchocla7e
I appreciate the advice about reading the manual. guys.
I know what every other warning light means.
This one, I didn't.
I never had a car with the an automatic tire pressure monitoring system. I'm behind the technology curve a bit.
Thanks
Old 10-12-2012, 04:53 PM   #7
jesperswe
Drives: GT86
Thanks
That's what the manuals are for I've never had a GT86 before so the first thing i did was to fast check the manual and see what all the lights mean in case they would pop up
jesperswe is offline   Reply With Quote
Old 10-12-2012, 05:14 PM   #8
kykiee
kykiee's Avatar
Drives: 13 Subaru BRZ, 02 Toyota 4Runner
It's okay. I was in the same boat. I didn't know what the TPMS light was until it came on a few days ago. I had to check the manual. lol
2013 Subaru BRZ Limited - GBS - 6MT - VIN #01197
kykiee is offline   Reply With Quote
Old 10-17-2012, 04:43 AM   #9
RD1428
RD1428's Avatar
Drives: 2013 Scion FRS
when its cooler outside air particles get closer together causing the air pressure in you tires to go down, as your tires warm up the air inside your tires will expand causing the pressure to go back to normal. Thats why the light came on, on a cold day
RD1428 is offline   Reply With Quote
Old 10-17-2012, 05:06 AM   #10
Ravenlokk
Ravenlokk's Avatar
Drives: 2013 Raven FR-S
Theres a manual?
jk :P... Maybe i should put it in the bathroom, so i actually look at it.
Ravenlokk is offline   Reply With Quote
Old 10-17-2012, 08:00 AM   #11
brichard0625
brichard0625's Avatar
Drives: 2013 Scion Frs(Scarlet)
Mine comes on all the time even when i put more air in the tire...Anybody experiencing the same...yesterday my air pressure was at 38psi and the light is still up wtf...the car is starting to piss me off
brichard0625 is offline   Reply With Quote
Old 10-21-2012, 03:59 PM   #12
ill86
VehicleDynamicsSpecialist
ill86's Avatar
Drives: iG FR-S
Bump
"The best track modification you can ever make is between the steering wheel and seat." - CSH
ill86 is offline   Reply With Quote
Old 10-21-2012, 04:06 PM   #13
MY13FRS
***** Super Senior Member
MY13FRS's Avatar
Drives: 13 FRS
All the cars that I've owned that has TPMS never seems to work right. IMO, they designed them to be too sensitive. Not good if you live in a colder environment.
I always set my tires to 5psi higher than stated on the label. Still, can't get away from the annoying warning lamp.
The lamp on my FRS has been on constantly for the last 2 months. I checked the tires pressure once in a while and they are even 3psi above the door label.
MY13FRS is offline   Reply With Quote
Old 10-21-2012, 04:20 PM   #14
TIE Pilot
TIE Pilot's Avatar
Drives: TIE interceptor; BRZ13
@op you might know by now. just in case the correct tire pressure is also labeled on the frame of the drivers door
^thasts why i inflated mine with N2 ($30). This also affects gas milage, tire life, water condensation & safety in general.
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." Jeremy Clarkson
TIE Pilot is offline   Reply With Quote
Issues - Traction control and ABS warning light on G86 Issues | Warranty | Recalls / TSB 109 10-17-2021 04:32 PM
ZILLA: (How-To) *REAR FOG LIGHT WITH BRAKE LIGHT* MOD! ZILLA DIY (Do-It-Yourself) Guides 117 09-19-2017 10:17 AM
experiencing tail light + fog light condensation? whyreeto AUSTRALIA 20 01-14-2013 11:15 PM
TPMS warning light **New Info** sdiver68 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 29 10-11-2012 07:25 PM
Risk Racing Light Mine Professional Magneti - Magnetic mini light fixture! DjDATZ Off-Topic Lounge [WARNING: NO POLITICS] 0 06-28-2012 11:21 AM
