Old 12-24-2012, 12:06 PM   #1
Roborat
Drives: Scion FR-S firestorm red
DIY wired angel eyes to on/off with ignition
Hey guys sorry I took WAY too long to get this posted. I don't like having to turn the angel eyes on and off with the parking lights and all that so I wired them in to come on and off with the ignition. As everyone knows there is a 12V source in the glove box. This comes on with the ignition so I tapped this wire for the angel eyes. You will need to but some extra electrical wire that u can get at any home improvement store or radio shack. Once the angel eyes are installed into the headlight housing you want to run the wire along the side of the engine bay and to the large rubber grommet on the passenger side. This is where it get a little tricky. You can remove the grommet undo the electrical take and run the wire through the grommet with the rest of the electrical wiring. Be sure to rewrap the wires with electrical tape once you have fed this wire through it. Now tap the 12V source with a wires using a t-tap. These wires can be hard to reach so I removed the glovebox and the side panel to have more room to work. Once you are tap it reinstall everything and DONE. Turn on your car any enjoy having halos that don't have to be manually turned on and off.
Roborat is offline   Reply With Quote
Old 12-26-2012, 10:09 AM   #2
Fallen hero
Becuz RACE CAR
Drives: FR-S Raven MT
Originally Posted by Roborat View Post
Hey guys sorry I took WAY too long to get this posted. I don't like having to turn the angel eyes on and off with the parking lights and all that so I wired them in to come on and off with the ignition. As everyone knows there is a 12V source in the glove .................
What kind of halos are you using ccfl or led
And what is its diameter
Fallen hero is offline   Reply With Quote
Old 12-26-2012, 01:56 PM   #3
Minovsky
Minovsky's Avatar
Drives: Fr-s 2013 white out
wish there was a video tutorial D:!! or more pictures of step by step maybe?
Minovsky is offline   Reply With Quote
Old 12-26-2012, 05:53 PM   #4
Roborat
These are the new LED from the retrofit source. These are 90mm, you can also use 80mm I believe from other posts on here.
Old 01-29-2013, 05:03 AM   #5
jet86
Mad Sciontist
jet86's Avatar
Drives: gt86
Just to let you know, I did the same thing, there is a 12v ign switched wire in the fuse box loom. (red with blue stripe). It also supplies the alternator with ign power.
jet86 is offline   Reply With Quote
Old 01-29-2013, 12:15 PM   #6
MrTranxD
MrTranxD's Avatar
Drives: Scion FR-S
I ran a wire to my cigarette lights like what the op did but i added a switch so i can turn it off if i wanted to. works Great. lol
2013 Ultramarine FR-S 6MT
MrTranxD is offline   Reply With Quote
Old 01-29-2013, 08:11 PM   #7
ph0en1xtk
ph0en1xtk's Avatar
Drives: Raven MT Scion FR-S
im about to wire up my angel eyes, and i was looking for something like this as i want to use my glove box wire for my radar detector. any more information on what this wire looks like and how to hook it up?
ph0en1xtk is offline   Reply With Quote
Old 01-29-2013, 08:16 PM   #8
Vanga
Vanga's Avatar
Drives: 07 Hyundai Tiburon SE
The 80mm fits better on the bezel. Just run the wire out through the vent cap and splice it into the parking light, this way the AE always lights up with the parking light. Easy as pie.
Vanga is offline   Reply With Quote
Old 01-30-2013, 01:49 AM   #9
jet86
Mad Sciontist
jet86's Avatar
Drives: gt86
If you go to the back of the fuse box you can cut the tape around the entry to the fuse box around the main loom. You can find the wire in that loom, I tapped it there and ran the new wire out the side of the side of the fuse box where all the other headlight power comes from. Pretty simple really.
Old 01-30-2013, 03:28 AM   #10
MrTranxD
MrTranxD's Avatar
Drives: Scion FR-S
What he said ^^ probably works too. lol
Old 01-30-2013, 04:46 PM   #11
Tylub
Tylub's Avatar
Drives: Raven Black FR-S
@MrTranxD i see you have changed your name... switch = stealth missions
instagram @Tylub
Mods: Tomei UELs, Tomei OP, Perrin Catted FP, ARK DT-S, Perrin LW Crank Pulley, Enkei RPF1, RSR Sporti, Supertek Intake Tube, Perrin CAI, Stoptech SS lines/brakes/slotted rotors, Cusco MCB brace/Strut Bar
Tylub is offline   Reply With Quote
Angel Eyes installed on and off with ignition!! Roborat Cosmetic Modification (Interior/Exterior/Lighting) 87 09-06-2013 01:04 AM
What's with the bug eyes? Eau Rouge Cosmetic Modification (Interior/Exterior/Lighting) 8 11-16-2012 01:40 PM
*** Front Lighting Modifications HID Headlights LED Angel Halo Custom Housing *** zAnSh1n Cosmetic Modification (Interior/Exterior/Lighting) 21 04-04-2012 04:41 PM
