Old 03-24-2012, 03:12 AM   #1
zAnSh1n
♥カレー大好き !!
zAnSh1n's Avatar
Drives: ♿
Exclamation *** Front Lighting Modifications HID Headlights LED Angel Halo Custom Housing ***
This thread will discuss headlight modifications on the FR-S.
I will keep links to a minimum to avoid promoting external sites, but links will be provided by the users on a need-to-know basis.
The factory headlights on the FR-S are unique in that it is different than the [GT]86/BRZ variants. It does come with projectors and a dedicated high-beam unit, but they are halogens and not HIDs.
There is not much else aside from the inner housing / reflector inside the headlights since the turn signals and parking lights are located on the bumper.
If you get the fog light option thru Scion, they provide a new trim piece and the fog lights go under the turn signals the same way as the Toyota [GT]86, since they share the same front end.
The JDM vehicles also come with clear parking lights, which will be a popular simple upgrade.
Aside from the minor differences in front lighting design between the FR-S and the BRZ, the FR-S also does not come equipped with headlight leveling switch inside the cabin.
The BRZ [not sure about the 86] is capable of adjusting the low-beam headlights vertically. The dial switch is located next to the trunk button and on the FR-S, it is covered by a blank panel.
Some people may choose to swap out their headlights with the JDM units [seen on the orange 86 above], which includes the LED driving light strip.
This option will be costly and slightly cumbersome since you will have to import them from Japan and you need to worry about adjusting the light beams to aim correctly for the US driving direction [oncoming traffic on the left].
One of the more popular modifications will be to install an HID kit to replace the factory halogen system.
Since the low-beams are projectors and there are dedicated high beams, the whole upgrade will essentially be plug-and-play and bi-xenon kits are not required.
Personally, modifying/upgrading my headlights will be the first mod I will be performing to my FR-S.
I will most likely paint the inner housing black, leaving the ring around the low-beams chrome, and upgrade the halogen units to 8k HIDs.
Stick around for more information to come and I can't wait to see some of our more hardcore members to modify the projectors, add custom shrouds/angel eyes/light strips, etc...
Please feel free to share your modification plans and any relevant information.
Thanks for stopping by and happy modding
zAnSh1n is offline   Reply With Quote
Old 03-24-2012, 03:13 AM   #2
zAnSh1n
♥カレー大好き !!
zAnSh1n's Avatar
Drives: ♿
reserved.
Old 03-26-2012, 08:04 AM   #3
Saibot
Saibot's Avatar
Drives: 01 Toyota Corolla / Porsche 911 C2
nice! question though.. Does the JDM toyota lights have hi-beams then??
Saibot is offline   Reply With Quote
Old 03-26-2012, 09:46 AM   #4
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Saibot: The HID GT86 headlights are bi-xenon, so halogen hi-beams are not required.
Zanshin: We currently have no idea how good those halogen projectors are. They might suck.. badly. If they are subpar, putting a PnP HID conversion setup in them will produce extremely poor results. Also, 8000K HIDs are going to just add to that misery since they put out less light anyways than 4300K HIDs. If you want proper results, and are already taking the headlights apart for cosmetic changes, why not install some FXR projectors (awesome projectors), TSX or S2K (also awesome and not bi-xenon so it's "easier") projectors?
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 03-26-2012, 12:39 PM   #5
Crashoverride
here, there, any where
Drives: FR-S SOON!!!
Or Just get the German version of the lights, they will point in the right direction and be the same as the JDM ones without modifcation....
Crashoverride is offline   Reply With Quote
Old 03-26-2012, 02:40 PM   #6
zAnSh1n
♥カレー大好き !!
zAnSh1n's Avatar
Drives: ♿
i've decided to run 6000k instead... yes, still less output than 4300k, but i really don't care cuz i like the color, haha...
it's probably safe to assume the factory pieces aren't that great of quality, so i'll probably just swap them out with tsx units...
Old 03-26-2012, 02:41 PM   #7
zAnSh1n
♥カレー大好き !!
zAnSh1n's Avatar
Drives: ♿
that'll work, but still expensive
Old 03-26-2012, 02:45 PM   #8
merlin2111
merlin2111's Avatar
Drives: Widebody '94 Miata R-Package
When I put the 4200k on my RSX the light out put was incredible. I would love to have a set like this on my next car. Luckly I am leaning towards the BRZ so this shouldn't be a huge problem but I will keep this thread in mind because blackout housings are always sweet.
I <3 my Miata.
But I <3 my new BRZ even more!
merlin2111 is offline   Reply With Quote
Old 03-31-2012, 08:48 PM   #9
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
I know its probably way too soon, but does anyone know if the projectors use 2.5" or 3" lenses?
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 03-31-2012, 10:42 PM   #10
zAnSh1n
♥カレー大好き !!
zAnSh1n's Avatar
Drives: ♿
too soon to tell... for the angel eyes?
Old 04-01-2012, 01:04 AM   #11
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
No, angel eyes arent my style.
These are halogen projectors, which arent ideal for HID use. Ive got a few pairs of bixenon projectors here that I could drop in, both 2.5" and 3" lenses. Then Id simply turn the inner reflector into a dedicated DRL.
Parting out HERE
Old 04-01-2012, 03:30 AM   #12
zAnSh1n
♥カレー大好き !!
zAnSh1n's Avatar
Drives: ♿
ah, gotcha... you're swapping out the projectors
Old 04-03-2012, 10:15 AM   #13
robotvoice
Drives: 07 STI
Halogen projectors are designed much differently than HID projectors. They look the same on the outside but the bowl and cutoff shield inside the projectors are very different. A lot of people will immediately want to throw a cheap HID kit into these headlights but will wind up with very poor output and a lot of extra glare which can be unsafe for other drivers on the road.
Unfortunately there will be no true "plug and play" kit option that will yield great results. You will have to open the headlights and swap in true HID projectors or find a way to modify the halogen projectors to eliminate excessive glare.
robotvoice is offline   Reply With Quote
Old 04-03-2012, 12:18 PM   #14
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Yep, which is my plan.
Parting out HERE
Halo ODST Commercial (Epic)!! MR2fan Off-Topic Lounge [WARNING: NO POLITICS] 7 09-14-2015 01:29 PM
Automation Lighting offers LED interior/exterior kits jjdrivesajazz Interior Parts (Incl. Lighting) 393 10-11-2013 10:49 AM
Differences In Types of Headlights/Lighting Asphalt Cosmetic Modification (Interior/Exterior/Lighting) 7 02-21-2013 07:49 AM
Modifications and Your Vehicle Warranties Lonewolf Other Vehicles & General Automotive Discussions 6 01-14-2013 01:46 PM
Alternative Modifications for Baby Boomer Toyobaru Owners brzmaybe Scion FR-S / Toyota 86 GT86 General Forum 15 01-26-2012 11:14 AM
