Old 12-12-2012, 01:37 AM   #1
corvino26
corvino26's Avatar
Drives: 2013 Scion FR-S 6MT Raven
CEL after removing cat?
Will I get a CEL after removing my catalytic converter and replacing with a test pipe? Would an o2 defouler or eliminator be needed?
corvino26 is offline   Reply With Quote
Old 12-12-2012, 01:42 AM   #2
ngabdala
Vortech Supercharged
Drives: WRB BRZ 6MT LTD
You will not unless you change your header (also catted) to a non-catted. I can't see many if any aftermarket headers coming with a cat.
Powered by Vortech, ECS Tuning, and JDL Auto Design
ngabdala is offline   Reply With Quote
Old 12-29-2012, 05:17 PM   #3
corvino26
corvino26's Avatar
what i was thinking of doing was getting a catless header and putting a 02 delete on it like the one in the link below... any thoughts?
http://www.ebay.com/itm/O2-Oxygen-Se...5b7d00&vxp=mtr
Old 02-02-2013, 08:02 PM   #4
ngabdala
I've been banned from here for over a month but I still wanted to get back to you. I'm having a muffler shop do it for me.
Old 02-02-2013, 08:12 PM   #5
kosoku
Drives: 2013 fr-s
More than likely you WILL get a check engine light. The post o2 sensor will go nuts.
kosoku is offline   Reply With Quote
Old 02-02-2013, 08:16 PM   #6
AVOturboworld
Drives: 2013 "AVO Orange" FR-S
If you remove the primary cat in the header, you will definitely get a CEL if you don't take steps to compensate. If you remove the secondary cat, there's nothing back there to take issue with that fact.
AVOturboworld is offline   Reply With Quote
Old 05-16-2013, 04:36 AM   #7
corvino26
corvino26's Avatar
The part that I posted screws into the second o2 bung and the sensor screws into that piece... Once I get some cash up I will try it out and report back
Old 05-20-2013, 03:58 PM   #8
TAP Auto Parts
Drives: FRS
yes it will. I recommend the vibrant 02 simulator.
bj@tapautoparts
TAP Auto Parts is offline   Reply With Quote
Old 06-17-2013, 09:15 AM   #9
swift996
swift996's Avatar
This!
Some people have used washers to "fix" this issue. Search around the forum there's a lot on this. I have a catted header with no CEL issue.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Need help removing shifter trim spitz Cosmetic Modification (Interior/Exterior/Lighting) 10 09-28-2019 08:34 AM
removing the dash Surok Electronics | Audio | NAV | Infotainment 6 01-24-2014 12:06 AM
Removing decals sa1126 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 3 07-12-2012 12:48 PM
Removing pinstriping Zxtole Cosmetic Modification (Interior/Exterior/Lighting) 15 06-10-2012 08:12 PM
Removing the roof antenna denkigrve Cosmetic Modification (Interior/Exterior/Lighting) 8 05-16-2012 11:59 PM
