Old 06-10-2012, 12:22 PM   #1
Zxtole
Removing pinstriping
Hey all, just picked up my Fr-s (Ultramarine, great color).
Anyway one of the installed options was pinstripes down the sides and I haven't seen any posts yet on the forums and I'm rather new to modding. What is the best way to remove them without access to a hair dryer?
I read about using goo gone as well as a heat gun but goo gone didn't seem to have any effect on it as well as a heat gun seems a little excessive and have no experience operating one.
Zxtole is offline   Reply With Quote
Old 06-10-2012, 01:43 PM   #2
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Park it in the sun and carefully peel it away after it heats up. Then you can use Goo Gone or Turtle Wax bug and tar remover to get the rest of the adhesive off.
The professional way to do it is to use a stripper wheel on an air drill.
Old 06-10-2012, 03:00 PM   #3
Zxtole
Thanks for the quick response, so far no luck after a few hours in the sun. Seems much more stubborn then other pinstripes I've had to remove that just came off with my finger nail.
Old 06-10-2012, 03:24 PM   #4
mines13
mines13's Avatar
Drives: '13 FR-S '12 CBR1000RR
Send a message via AIM to mines13 Send a message via Yahoo to mines13
The fact that they would even put a pin stripe on this car offends me. It is 2012.
mines13 is offline   Reply With Quote
Old 06-10-2012, 03:25 PM   #5
moniz
moniz's Avatar
Drives: 2010 Mazda5 GT,2012 Honda Fit Sport
Why do car dealers still do this sh*t?!? Unless a customer specifically ask for it, leave the damn car alone from the factory! I personally wouldn't have bought it unless it was removed or waited for another one. Sure I'd want the car bad, but not bad enough to let dealers get away with this garbage!
Past-'89 Civic Si ('93-'99)-'94 Civic Si ('99-'07)-'07 GTI(Lease)('07-'10)'98 Acura EL ('03-'13)Current-'12 Honda Fit Sport'10 Mazda5 ('10- Family car)No FR-S for me Kids in car seats still and just wouldn't work in an FR-S especially in winter.
moniz is offline   Reply With Quote
Old 06-10-2012, 03:28 PM   #6
Zxtole
Yea, I agree. I didn't even realize it was an option until I saw it. Haven't even seen one on here yet with that option. Still doesn't even seem to want to come off. I guess I'll have to invest in some real equipment to remove it, curses.
Old 06-10-2012, 03:34 PM   #7
michaelahess
michaelahess's Avatar
Drives: '13 GBS BRZ Lim, 2006 Dodge RAM MC
If you are VERY careful, use a razor blade to lift one edge and either a heat gun or hair dryer (yea I know you said you don't have one, ask a lady relative) and slowly pull it at about a 30 degree angle while applying just a bit of heat.
I've taken off a lot more vinyl tape than I'd like to admit...
Use turpentine or goo-gone (terp is quicker but harsher) to get rid of any residual glue, then wash with alcohol and wax that spot.
michaelahess is offline   Reply With Quote
Old 06-10-2012, 03:37 PM   #8
Probably a stupid question, but given how stubborn its being, you sure its not paint?
Old 06-10-2012, 03:49 PM   #9
Zxtole
Yes the issue is that I have one, but I have no garage and no way of reaching to an outlet in order to give it power. I appreciate the advice though, I will be able to do it at a friends home when get comes back but I'm sort of restless when it comes to finishing things.
Yes, while you do have a point, I did already manage to pull of half of it on one side, and it came off just fine. However it just stopped wanting to come off after awhile and just wont now. So I can confirm it isn't paint, it's just really obnoxious.
Old 06-10-2012, 03:55 PM   #10
Guess I missed the part where you had already pulled it half off!
Old 06-10-2012, 03:57 PM   #11
Zxtole
I hadn't mentioned it, I don't think I've even heard of painted on pinstripes from the factory. But might as well point it out in case someone else tries to remove them.
Old 06-10-2012, 03:58 PM   #12
Turbowned
Turbowned's Avatar
Just out of curiosity, did you buy this car in Florida? I feel like they're the only state that still puts that crap on their cars.
Old 06-10-2012, 04:02 PM   #13
Zxtole
Good guess, yes I did sadly. I'd recommend anyone who doesn't want them on double checking the options list.
Old 06-10-2012, 04:18 PM   #14
I doubt it came from the factory that way. They were probably added at port or at the dealer (most likely the dealer). I asked about the paint because years ago a relative of mine worked at a dealership where they used paint. Why? Because one of the guys in their body shop had been doing pinstriping by hand for something like 30 years, and he could do it faster and cheaper (and better) by hand than most folks could do otherwise.
Removing and Replacing BRZ/FR-S Intake, Air Filter and Noise Generator Delete GrimmSpeed DIY (Do-It-Yourself) Guides 99 01-25-2015 01:24 AM
Removing the 86 badge on the front of the car Pake1 Cosmetic Modification (Interior/Exterior/Lighting) 1 06-10-2012 08:37 AM
Ease of removing stock exhaust Evil86 Engine, Exhaust, Transmission 3 06-07-2012 09:05 AM
Removing interior trim dash panels ubersoph Cosmetic Modification (Interior/Exterior/Lighting) 7 05-30-2012 09:20 AM
Removing the roof antenna denkigrve Cosmetic Modification (Interior/Exterior/Lighting) 8 05-16-2012 11:59 PM
