Drives: 2013 Scion FR-S 6MT Raven
CEL after removing cat?
Will I get a CEL after removing my catalytic converter and replacing with a test pipe? Would an o2 defouler or eliminator be needed?
#2 |
Vortech Supercharged
Drives: WRB BRZ 6MT LTD
You will not unless you change your header (also catted) to a non-catted. I can't see many if any aftermarket headers coming with a cat.
#3 | |
http://www.ebay.com/itm/O2-Oxygen-Se...5b7d00&vxp=mtr
A.Corvino
http://www.streetmasters.com/ |
#4 | |
I've been banned from here for over a month but I still wanted to get back to you. I'm having a muffler shop do it for me.
#5 |
Drives: 2013 fr-s
More than likely you WILL get a check engine light. The post o2 sensor will go nuts.
#6 |
If you remove the primary cat in the header, you will definitely get a CEL if you don't take steps to compensate. If you remove the secondary cat, there's nothing back there to take issue with that fact.
#7 |
The part that I posted screws into the second o2 bung and the sensor screws into that piece... Once I get some cash up I will try it out and report back
A.Corvino
#8 |
Drives: FRS
yes it will. I recommend the vibrant 02 simulator.
bj@tapautoparts |
#9 | |
Some people have used washers to "fix" this issue. Search around the forum there's a lot on this. I have a catted header with no CEL issue.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread) ![]() |
| Need help removing shifter trim | spitz | Cosmetic Modification (Interior/Exterior/Lighting) | 10 | 09-28-2019 08:34 AM |
| removing the dash | Surok | Electronics | Audio | NAV | Infotainment | 6 | 01-24-2014 12:06 AM |
| Removing decals | sa1126 | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 3 | 07-12-2012 12:48 PM |
| Removing pinstriping | Zxtole | Cosmetic Modification (Interior/Exterior/Lighting) | 15 | 06-10-2012 08:12 PM |
| Removing the roof antenna | denkigrve | Cosmetic Modification (Interior/Exterior/Lighting) | 8 | 05-16-2012 11:59 PM |
