Old 10-28-2012, 03:43 PM   #1
spitz
spitz's Avatar
Drives: '13 SWP BRZ-L
Need help removing shifter trim
I recently purchase my JDM knee pads and in the midst of installing them. However I've run into a wall; I can't seem to remove the outer shifter trim and was wondering is the best way to remove? I've looked at several threads already and it seems the only one that comes close is the JDM Knee Pad Install DIY, but even there it just says to pull with no in depth details.
Do I pry with a flat head? I can't seem to get the screw driver down deep enough for a solid pry. Or, do I pull upwards on the trim while gripping the trim around the outer circumference of the shifter boot?
I'm doing my best not to damage trim at all.
Any help would be greatly appreciated, thank you!!
spitz is offline   Reply With Quote
Old 10-28-2012, 04:44 PM   #2
wawro569
Drives: 2013 Scion FR-S MT
I just did this actually, the bst way is to lift up the plastic covering where the armrest should be and you'll see two screws there, unscrew both. Then lift up the vinyl base around the handbrake, pulling straight up until it comes off. Then youll be good to take off the shifter base, make sure to unplug the VSC buttons.
wawro569 is offline   Reply With Quote
Old 10-28-2012, 04:52 PM   #3
mezdup
#1362
mezdup's Avatar
Drives: 2014 Ice Silver WRX
this video helped me quite a bit. i think it may help you in this as well:
mezdup is offline   Reply With Quote
Old 10-28-2012, 04:55 PM   #4
Gen
Drives: Scion FR-S
Stick your fingers into the shift boot and get a good grasp with the tips of your fingers on the side of the trim piece and lift straight up. It literally takes about 5 seconds to remove.
Gen is offline   Reply With Quote
Old 10-28-2012, 08:04 PM   #5
spitz
spitz's Avatar
Thanks for the help everyone, I'll give it a try!
Old 03-05-2013, 09:22 PM   #6
stea1thbear
Drives: Scion FR-S Firestorm
Should the shifter trim come off the same way on an automatic? I've also read all the threads and it doesn't seem to want to budge.
stea1thbear is offline   Reply With Quote
Old 03-05-2013, 09:38 PM   #7
DSOmegaX
DSOmegaX's Avatar
Yes, it comes off the same way. Remove the handbrake boot to expose an opening underneath the shifter trim, place a trim removal tool or flathead screwdriver underneath the trim and lift up. You should hear the clips unsnap. Work your way around the base of the trim as each section lifts up.
@dsomegax.cars
Old 08-14-2013, 05:40 PM   #8
MadFRS
MadFRS's Avatar
Drives: UltraMarine FR-S
Exactly what I just tried. Super easy!
Do one side at first, then work towards the buttons.
Thank you!
She's Gone....
Flickr Page
MadFRS is offline   Reply With Quote
Old 12-17-2015, 10:57 PM   #9
Slade
Slade's Avatar
Drives: 14 Limited BRZ
Do you need to remove the shift knob first? (referring to the automatic)
Slade is offline   Reply With Quote
Old 09-27-2019, 11:24 PM   #10
iconic
Drives: 2015 Scion FRS Auto
yes.
iconic is offline   Reply With Quote
Old 09-28-2019, 08:34 AM   #11
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
If it won't budge double check to make sure you've found all the bolts. There are bolts everywhere on that damn thing. Had to check 3 different places to find where they all are. Then just brute force the damn thing. It just doesn't want to budge.
Interior trim trim clips (Dash Trim Panel) ubersoph Cosmetic Modification (Interior/Exterior/Lighting) 4 08-11-2022 07:47 AM
Manual MT Shifter Boot Swap Onto Automatic AT Shifter Assembly? soulstice Cosmetic Modification (Interior/Exterior/Lighting) 52 01-24-2016 08:20 PM
removing the dash Surok Electronics | Audio | NAV | Infotainment 6 01-24-2014 12:06 AM
WTT: BRZ(mine) trim pieces for FRS(yours) trim pieces Flat Black VW Interior Parts (Incl. Lighting) 14 07-27-2012 10:01 PM
Removing interior trim dash panels ubersoph Cosmetic Modification (Interior/Exterior/Lighting) 7 05-30-2012 09:20 AM
